A man made this project? if someone can tell me the exact value of the coil to me, please, thanks in advance ...
TGSL problem,Hello everyone, can someone help me ?
You should reduce your project (Tesoro Golden Sabre, or TGS) to the TGSL. TGSL should be difficult enough for any knowledgable electronics technician... but when you add notch filters as in the original factory authorized design, it becomes an absolute necessity that you have more than only a rudimentary knowledge of what it supposed to happen.
Pay attention to KT315 and the King Cobra. It is very closely related to the TGS, but I tell you this: Learn to walk before you try to run.
Tesoro's technicians (most likely) had step-by-step instructions to setup the TGS and appropriate test instruments.
I still mounting all the same symptoms sounded continuously, we tested coils TGSL Edu and works, I checked ICs and replaced we are good there is no problem, maybe someone can help me, thanks in advanceAttached Files- 20140423_225242.jpg (477.8 KB, 76 views)
