Coil Tesoro Silver Umax to Tesoro Eldorado
  • Coil Tesoro Silver Umax to Tesoro Eldorado
    Hi all
    I have a question, probably trivial
    Is coil concentric coil (8") with the Tesoro Silver Umax will fit to Tesoro Eldorado ?
    The frekfrency operating is thesame 10kHz
    Thanks for the answer
    Regards.
    Originally posted by aothunterpl View Post
    Hi all
    Regards.
    The Silver uMax coil should work on the Eldorado. You can easily check this by looking at the coil plug, which will either be 4-pin or 5-pin. They have different inductance values for the TX and RX coils. I think the coils you mentioned are both 4-pin types.
    However, you may need to adjust the ground balance for optimum performance.
