how much .45mm wire needed for igsl-tgsl home made coil ?
  • how much .45mm wire needed for igsl-tgsl home made coil ?
    hi, any body know how much .45 mm ecw is needed to make your own coils for the igsl-tgsl detector ?
    thanks, mark k
    I believe it is 21" per turn for the 9" coil.
    So at 45 turns (45x21=945/12=78.75) about 80 feet.
    That's assuming your making the Minelab coil...
      hi, i suppose i should have said it was the coil for th e igsl-tgsl on the silverdogs site... it needs 107 on one coil and 98 turns on the other.. thanks,
      mark k
        OK so that's a 10" coil (I just built one of those) that would be 25" per turn
        so 25*107=2675"/12=223 feet
        25*98=2450"/12=204.1 feet
        205+225=430 feet needed to make one coil (or 131 meters)
        Um I thought you were doing the Minelab as you said 0.45 mm as might be used on the TX for that coil.
        SilverDog's docs say;
        So, to finish this exact coil i need 107 windings for RX and 98 windings for TX. Wire at both
        coils is the same; 0.25mm Cu (0.27-0.28mm with resin layer).
        0.25 mm
