SMT Bandito Info/Build
  • SMT Bandito Info/Build
    Here's some info on the SMT Bandito board;
    The layout files as JPG's and a viewer to look at the
    Sprint? original file
    Here's the lay file in a zip;
      Here's a zip file with the components list (oops resistors and caps only) and a shopping list
      (only resistors so far) and the schematic I will use. The component list shows some values
      that are different on Chemlic's schematic. As the board is basically an updated Golden
      Saber I'd suggest using values closest to what that board uses.
        Here's a filled out Component list;
        Components list:
        R1-1.2K
        R2-12K
        R3-20K
        R4-47K
        R5-10K
        R6-10K
        R7-2.2K
        R8-200K
        R9-100K
        R10-100K
        R11-200K
        R12-430K
        R13-1K
        R14-20
        R15-5.1K
        R16-150
        R17-100
        R18-150
        R19-82K
        R20-1K
        R21-10K
        R22-20K
        R23-100K
        R24-20K
        R25-20K
        R26-5.1K
        R27-5.1K
        R28-100K
        R29-100K
        R30-1K
        R31-20K
        R32-20K
        R33-20K
        R34-47K
        R35-100K
        R36-100K
        R37-100K
        R38-2.7M
        R39-200K
        R40-2.7M
        R41-470K
        R42-1K
        R43-1M
        R44-5.1K
        R45-1M
        R46-5.1K
        R47-47K
        R48-47K
        R49-620K
        R50-620K
        R51-10K
        R52-150K
        R53-1K
        R54-4.7K
        R55-4.7K
        R56-1M
        R57-1M
        R58-200K
        R59-200K
        R60-2.2K
        R61-100K
        R62-20K
        R63-100K
        R64-10K
        R65-??
        R66-200
        R67-1K
        R68-10K
        R69-27K
        R70-10K
        C1-470nf
        C2-47nf
        C3-??
        C4-100UF
        C5-100UF
        C6-220Uf
        C7-10Uf
        C8-220Uf
        C9-100pf
        C10-130PF (22pf)
        C11-??
        C12-180pf
        C13-22pf (10pf)
        C14-18pf (8.2pf)
        C15-33nf
        C16-120pf (39pf)
        C17-220nf
        C18-30pf (22pf)
        C19-100nf
        C20-100nf
        C21-100nf
        C22-10nf
        C23-10nf
        C24-10nf
        C25-100nf
        C26-??
        C27-??
        C28-10nf
        C29-10nf
        C30-0.47Uf
        C31-0.47Uf
        C32-22nf
        C33-22nf
        C34-100nf
        C35-10nf
        C36-100nf
        C37-0.47Uf
        C38-4.7Uf
        C39-4.7Uf
        C40-??
        C42-100UF
        IC1 - CD4024
        IC2 - 2931A (LDR)
        IC3, 6, 10 - TLC22262
        IC4 - CD4066
        IC5, 8 - LM393
        IC7, 9 - MC33178
        4 - 2N3906
        3 - 2N3904
        9 - 1N4148
        2 - 1N5819
        Disc Pot - 100k
        GEB Pot - 50K
        Threshold Pot - 100K
          Tips on soldering surface mount components.
          Get the smallest tip for your iron that you can find.
          Get some solder wick (preferably thin like 1/8" 3/16")
          Get a good set of tweezers to hold the parts.
          Set the component next to the place you will solder it
          in the correct orientation.
          Put a small bit of solder on one pad.
          Set the component in place trying to hold it perfectly positioned (a magnifier can help).
          Heat the pin and solder, this will tack the component in place.
          You can still change the position by heating the one soldered pad.
          Make sure it is square on all sides and flat against the board.
          Solder another pin. This fixes it in place. It is now hard to remove so it better be right!
          Now solder the rest of the pins.
          If the pins are tiny and close you might make a solder short, that is OK.
          On tiny pinned parts we sometimes flood all the pins then remove the excess.
          The way this is done is to use solder wick.
          Try to solder quickly with minimum solder and remove excess quickly to avoid
          heating the part too much. You sometimes take too much back out so doing
          it quickly allows more to stay behind. A good joint has a filet to the board.
            Doing a little research and these seem to be the correct cap values;
            C1-470nf
            C2-47nf
            C3-??
            C4-100UF
            C5-100UF
            C6-220Uf
            C7-10Uf
            C8-220Uf
            C9-100pf
            C10-22pf
            C11-??
            C12-180pf
            C13-10pf
            C14-8.2pf
            C15-33nf
            C16-39pf
            C17-220nf
            C18-22pf
            C19-100nf
            C20-100nf
            C21-100nf
            C22-10nf
            C23-10nf
            C24-10nf
            C25-100nf
            C26-??
            C27-??
            C28-10nf
            C29-10nf
            C30-0.47Uf
            C31-0.47Uf
            C32-22nf
            C33-22nf
            C34-100nf
            C35-10nf
            C36-100nf
            C37-0.47Uf
            C38-4.7Uf
            C39-4.7Uf
            C40-??
            C42-100UF
            The suspected values were read in circuit. Then later they were removed and read properly...
              Looking forward to this detector. Be nice to compare to the IDX which is very similar. People who have had a Bandido love and miss them will be interesting to find out why. Seems to be the forgotten Tesoro on this site
              Cheers for all the hard work quite a few seem to have been made (not surface mount) via a German website which sold a PCB for them
              http://www.microsofttranslator.com/b...topic%3D9655.0
              just reading through the forum at the moment to see if there are any more pitfalls.
              See the power draw of the IC's is critical as some have used subsitutions that are better but draw more current then have trouble with the power rails.
              Also the original appears to only supply just under -3 volts and some people have used two schottky diodes in the PSU to fetch it up to -4 volts but can't see if this causes other problems
              After all the original worked fine
                Some more information on this forum under the TGSL mode CMS tread including one mistake on the legend
                http://www.geotech1.com/forums/showt...787#post156787
                  Well on the negative supply. I'd try to get as much voltage as possible just because it
                  seems right. At work we use similar circuits and we get 4.1 - 4.7 for the negative supply.
                  I'm going to use the schottky's to get a better output though on some units we put a diode
                  in series with the battery and use the far side as - 0.5v for just a tickle of negative voltage.
                  We clamp the signal at 0.6v at the second filter stage anyway so it might not matter much.
                  I had tried to come up with a way to drive the negative voltage generator with the direct TX
                  frequency. A question, why did they use a pass regulator when there is not enough voltage
                  available? Usually you use that to throw away excess voltage....
                    Resistor pads are 3mm x 1.5mm does that mean 0805 (2012 metric) are going to be the best fit
                    Would this be a good choice
                    http://uk.farnell.com/panasonic/era8...6/dp/1717745RL
                    metal film and available in quantities of 5 and quite a range of sizes
                    Looks like Tesoro did not use tight spec components
                    Quote from another forum
                    "and just how well it worked. That is the tricky part because I found there to be quite a variance between batches of Tesoro's of the same model. If I ordered in let's say 10 units of the same model, like the original Bandido, I might discover that 1 or 2 would be a bit wimpier than the average unit, and 1 or 2 might be a 'hot-performing' specimen. I was a Tesoro Dealer (obviously) at the time and I checked out every unit that came in prior to sale to ensure everything worked."
                      Yes 2012 would be 0805 but the ones you linked were 1206. Did you get your pcb from SilverDog?
                      I am waiting for mine but would like to see the pcb (both sides) to plan my parts list and verify
                      which schematic we are working to. I found a German schematic this morning that uses the battery
                      check circuit that's in the layout. It's different from the original Carl one and Chemelec's.
                      I read the earlier models worked better than the Bandito UMax. Probably because of the power setup. My
                      plan was to build it into a housing from a Tracker IV. It already has 2 9V batteries so maybe some improvments
                      can be made? I wondered why they didn't use +-15V for the old op amps to get the max headroom. There is a
                      lot of dynamic range in the return signal. Instead they compress the heck out of it and then trigger on mv's.
                      The variation you talk about appears in most detectors. I think that's why some say each one is great
                      and some say each one stinks. I had a Radio Shack that worked pretty good but the coil was advertised
                      to be waterproof, well it wasn't and when I brought it back they exchanged the whole unit. The new one
                      just didn't work as well.
                      The coil will make a difference too. Ivonic said 1 out of every 4 coils he made was just not quite as good. The
                      beauty of making it yourself is you can tune it for a long time to make it the best it can be. The commercial
                      ones get a 1 minute test and then are off to be sold...
                      Here's that schematic;
                        Yes I have the silverdog PCB looks very good and much better than trying to etch my own.
                        Can take some better photos in daylight if you need them
                        97.5mm x 71mm
                        pads 3mm x 1.5mm approx for resistors
                        4.4mm x 2.1mm approx for caps
                        Yes I read also the original Bandido was very good. There were 4 Bandido's the most desirable ones were the original and the last. The last Bandido II umax was slightly deeper but the original had crisper sound on good targets and less chatter in iron infested ground.
                          for the capacitors I take it that 1206 (3216 metric) is the best size
                          can only find a few metal film in either Polyethylene Naphthalate and Polyphenylene Sulphide in limited sizes
                          Same with the Resistor 0805 (2012 metric) can find some metal film but not every size
                          at Farnell and RS
                          Don't see the point in scrimping on components if there is a stabilizability advantage have to look elsewhere
                            Those photo's are good. I was just checking to make sure my docs matched. It looks like the circuit
                            matches the last schematic I attached. It uses a slightly different battery monitor.
                            For the components I have found some values are not easy to find in some sizes. The caps seem to
                            be different sizes depending on value. I have different sizes / values available at work so I can "try
                            before I buy" to make sure to order the correct ones. It's hard to tell from the pictures but the pads
                            seem larger to me. A too big component can be used but is hard to solder as the pads are underneath it.
                            Here's a link on pad sizes; http://en.wikipedia.org/wiki/Surface-mount_technology
                            Looks like 3mm x 1.5mm = 1206 for resistors
                            4.4mm x 2.1mm =1806 for caps
                            So 1206 should work for both
                              I have decided to get this enclosure mainly due to the ease of making a waterproof cover.
                              I built a really nice enclosure for my IDX with a separate compartment for the battery but attached it under the stem this has made it very difficult to waterproof and also very easy to knock the controls. Have spent half an hour on the beach at night wondering why I had no signals before I realized that the disc was turned all the way up
                              Weathers is good tomorrow so a trip to the beach with the IDX not been out detecting for about a month.
