TGS concentric coil
  • TGS concentric coil
    Please who can tell me ,original concentric coil for TGS ( Inductance ) ? Thanks in advance
    Here
    http://www.geotech1.com/cgi-bin/page...oils/index.dat
      Thanks,yes iknew the list but that is for Golden Sabre ,or any coil inthe list are functioning for Golden Sabre...?
        The Brown 8" Tesoro works on Golden Sabre...
          Yep brown is the normal one. http://www.geotech1.com/forums/showt...gsl+concentric should point you in the right direction
          Just notice that the first 5 are pretty identical as far as inductance goes probably within the error of measurements. However uMax 12x10 loos like an odd one out with resistance. Wounder if it had the short cable or thicker wire used for the windings?. If the latter was there a performance advantage?
            Well the Lobo one appears to be recorded backwards so either it was a factory mistake or
            maybe a recording error. Though one person swapped the RX and TX leads on his home made
            coil and got rid of the chatters that way...
              Thanks,all the best
