no sound..please help seniors and guru's..
  • no sound..please help seniors and guru's..
    This is my first time to build a vlf type detector.. can we get any sound from the speaker of the completed board without coil attached?? I finished one but i think it is not working , i cant heard any sound..
    First finish your detector, check your work a couple of time again before power on and then start alarm of non-working.
    If you have audio battery check in your design, then voice should be heard at power on, even with coil disconnected.
      Thanks WM6 now i know my board isn't working.
        Well you need a coil to test. The TX oscillations create the square wave for the sound output....
          Thank Silver dollar i gonna do that..
            still not working... in all ic's excpt 4020 i got a + 8v in pin 8 and pin 7 in opamf..but in all pin 4 i only got.73 volt.. im using. Ne5534 in replace of lm308.. would it be the culprits? Or it have some other suspects?
              Problem solve..it just a transistor markings in bord are reversed.. my tgsl is working now but a very low depth..
                How Many Voltage You Get From TX And RX
                  I got tx 27.7mV and rx 49.2mV..is this right?
