I'm in the process of trying to build a coil for my TGSL. I wound two coils that ended up with the following specs after binding, superglue and electrical tape:
TX Coil:
99 turns of AWG 30
5.80 mH
22.4 ohms
14.85 Khz when connected to oscillator
RX Coil:
104 turns of AWG 30
6.40 mH
23.9 ohms
14.14 kHz when connected to oscillator
These are off spec with dfbowers guide, but I was hoping they still might work.
I also have the correct voltages for LM358 pin 4 (-6.1V) and pin 8 (7.86 volts)
I arranged to coils so as to get as close to zero volts on pin 5 of U103 as I could:
But when I did that, the phases of J1-1 (TX) and U101 Pin 7 were separated by a lot more than the 20 degrees lag recommended by the guide:
So I probably know the answer to this question, but I'll ask it any way. Are my coils enough off spec to cause the separation between phases shown in the scope screen shot?
TX Coil:
99 turns of AWG 30
5.80 mH
22.4 ohms
RX Coil:
104 turns of AWG 30
6.40 mH
23.9 ohms
