https://www.geotech1.com/thunting/te...ndido2umax.pdf
Here is the B2uMax schematic. I also own a Bandido uMax, but it uses a ceramic thick-film substrate for the main circuit, and has laser-trimmed thick-film resistors. Therefore, it is almost impossible to trace out.
I mentioned a while back creating a page for commercial schematics. I wrote several detector manufacturers for permission to post old schematics, and the initial responses were pretty much the same: "sounds ok, let me check on it." Then, nothing.
So, I will go ahead with it, and if anyone complains, make adjustments as needed. If you have any schematics you want me to post, let me know. I do require that they be reverse-drawn off a circuit board, and not a copyrighted manufacturer's schematic.
