TGSL prints
  • Thank you CDI, I will try SMT Bandido, but later. In 2010 I had made Bandido DIP, from a German forum with 2 pcb. It is working, in all metall mode I can reach only 33 cm.
    But I had problem with discrimination, I was not able to found the mistake. So in my opinion TGSL is better.
    • I have that version with 2 pcb's but never maked one to see how it work's. That version is umax 2 version with some mistake.
      Well, look's like diy tgsl can do double distance detection than factory one tgs.
      Did u tried to replace LM308 with newer LT1115?
      Btw, today tried to replace LM833 with LF357 and device is more quiet, i was realy suprised.
      • Aha..I don't know the difference about Bandido and umax2.
        Yes I am very satisfied with my tgsl. Next weekend I have time, to finish the project, at first without vdi, the pic I have ordered from China, so I have to wait.
        I tried also different chips to replace, I think LF357 too, but as I remember right, LM833 gives more gain. LT1115 I have not.
        • What about coil spec's? Diameter, inductance, resistance, wire? On my 3.0 version i'm using standard parameteres: 6 and 6.5 mh, wire is 0.27. Resistance about 22 - 23 ohm's. Size is 27 cm.
          • I have for my TGSL/Bandido coil
            TX 6,0 mH, 20 Ohm, 99 turns 0,3mm
            RX 6,5 mH, 21 Ohm, 104 turns 0,3 mm
            DD27
            but not sure about wire diameter
            • That's it. Almost the same.
              • Originally posted by blobber View Post
                DD27
                Is the the 0,33mm the wire diameter ?
                • @ ripsdevala.
                  • Originally posted by chevesne View Post
                    @ ripsdevala.
                    [ATTACH]36911[/ATTACH]
                    Nothing change, still at 15cm
                    Guys tell me what to buy, HANTEK or INTRUSTAR?
                    I read some serious review about hantex and get a doubt about it.
                    INTRUSTAR
                    ISDS205A Virtual PC USB oscilloscope, 2CH 20 MHz 48MSa / s FFT analyzer, Data Logger
                    http://s.aliexpress.com/7NFf2qQv
                    HANTEK
                    From Factory Directly Hantek 6022BE 20MHz 2 channels 48MSa/s USB Digital Oscilloscope Dual Channel With 2 Probes
                    http://s.aliexpress.com/qayQfiAJ
                    • Blobber, is this a mod? 1N caps
                      • No, it is 100 nF.
                        • Comment
                          • About oscilloscope, I would say, both are good enough, I would choice the cheaper one of course.
                              Okay then I pick intrustar, hantek clone but the review is good.
                              What about this blobber, im right, right?
                              • As I already said, I change the connection until I get the best result. So I am not sure.
                                I think you have changed it already, right? When you get your oscilloscope, you will watch for the right wave form pin 7 of LF353 and TX/RX relationship in phase.
