What is phase shift and how
  • What is phase shift and how
    Bruh....
    What is phase shift 20 degree for DD and 200 degree for Concentric in tgsl, and how to do it correctly to do the test, its been 6 months and i still dont get it.
    Their talking about the phase differences between the Tx and Rx signal. Hope this helps. https://www.youtube.com/watch?v=30J5U0ThRUc
      I get it, where should i do the test from tgsl scheme for tx and rx shift.
        for tx look 1 field and stay in pin1 J1, thats hot end of your coil. for rx look 4 field and point on output of preamp.
          Thanks KT, you're the best.
            I think will be very interesting to know why the engineer decided to use a delay shift of 20° ...
            In other words, which was the necessity to shift RX signal?
            Can be to introduce a little delay to solve the problem relative to the exact point from where start to analyze the signal?
            I have also compared the ratio between TX and RX frequency but it seems different ...
