Hello, I have just finished the tgsl, problem it sounds continuously ??
Tgsl completed, help request
Hello, I just finished the tgsl, it sounds continually?
TGSL values:
Battery 11volt
R55 = 1.25v
R43 = -5.55v
R54 = 7.87v
LM308 pin4 = -5.55v pin7 = 7.97v
LM308 pin4 = -5.55v pin7 = 7.96v
LM358 pin4 = -5.35v pin8 = 7.96v
LM358 pin4 = -5.55v pin8 = 10.38v
LF353 pin4 = -5.55v pin8 = 7.96v
LM393 pin4 = -5.54v pin8 = 7.96v
LM393 pin4 = -5.57v pin8 = 7.96v
Originally posted by ashefr10 View PostHello, it used a TL081 instead of the LM308, it seems to me that it is necessary to remove the compensation capacitors of 100pF for it to work, could you confirm me, thank you
Hi FRIENDS, in the spirit of moving the forum I add an experience. Making some modifications to my TGSL I soldered the d12 backwards and the result was a constant pii although it did not stop detecting. I leave it as an experience just in case someone happens to you.
