TGSL SMD
  • #46
    Looks good. I could use a tape to prevent a connection between the enclosure and the rails.
    But it is still too big, i measure 70,8 mm.
    My enclosure is 70 x 100mm and i need a little bit space for speaker and pots.
    Sorry, and thanks!
    • #47
      even smaller
      • #48
        or you could go with bigger enclosure
        • #49
          The red frame is still 70,8mm but the green copper is about 69mm , i think it will work.
          I need to place the GB Pot more to the right and make the filled areas (corners) nicer.
          Im not sure about this layout by the way, i found somewhere in the internet its not tested.
          Thank You!
          • #50
            I've never seen this particular layout before, so be careful. I recommend only using proven layout, as it saves a lot of pain down the road.
            • #51
              I just finish the smd board with concentric coil
              Tx 6mh 20cm diameter
              Rx 6.5mh 10cm diameter
              Cx about 28 turn
              When i check the freq from Tx coil i got 13.2khz with air deep about 18cm.
              When i reduce the winding to get 14.5khz for Tx and 13.9 for Rx, the deep is very low...
              Any sugestion?
              • #52
                Cx about 28 turn
                Any sugestion?
                Your residual voltage is?
                Did you measure caps and inductance? for 22n and 220n with freq 13,2kHz I am getting 7,2mH. Something is wrong...
                • #53
                  I'm not sure with ny lcr...
                  What frequency should i get when i attach 3mH inductor to Tx J1, just for test.
                  • #54
                    [ATTACH]41886[/ATTACH]
                    [ATTACH]41887[/ATTACH]
                    Can you measure residual voltage + phase shift after first op amp Rx?
                    For 220n 22n and 3mH it should be 20,539 kHz
                    • #55
                      Ok, let me check, i only have this freq dmm and hantek scope
                      • #56
                        With 3mH inductor 20.51khz, i think the board is ok.
                        My lcr is crazy, thanks for the support, i need to reduce my coil winding to the required freq
                        • #57
                          My LCR is also big liar when it comes to inductance. I ordered DMM, which can measure inductance well and I was surprised by LCR error size It was in some cases up to 20%.
                          OK, and measure residual voltage after your correction!
                          • #58
                            Has somebody a partslist for the v1 layout?
                            Because im ordering parts.
                            • #59
                              All freq is correct, pin7 opamp 0.4v, air test only 16cm at max sens
                              Using Ne5532 as lf353 and 2N5485 for bf245
                              Let me try another ic and transistor
                              • #60
                                Did you try to use a standard DD coil with this pcb?
                                Im interested if it works. Because i want to build one too.
