Lf353 or Ca3240
    Everything you need to know is here in video, I hope this helps
    Everything you need to know is here in video, I hope this helps.
    https://m.youtube.com/watch?v=XnrStRklcUQ&t=16s
      tx 5v and rx 0.1mv dc but close to ivconic said rx4mv ac Is this frequency tuning really in thes vedio
        5V of Tx is very bad, should be 13-20V.
        Rx is also too low, 0.1 mV is far away from 4mV...
          These values ​​are given as the correct values 4mv~=.004v Is this true? It A meter must be read like this
            Can you show me please?
            All of my Tesoro-like coils has
            TX 15-18Vpp
            Rx 4-10mV.
            Working GEB, DISC, detection depth 30-35 for 1€ depend on coil size & settings... No chatters when touching.
              My tx now to j1 pin 1&2 =1.256v Means less than 2v
              My rx now to pin 7 lf353 and gnd =.002v
              Key geb and disc on the middle and put all metals
                Cheapo meter not have bandwidth to measure voltage of 14khz sine accurately, to measure peak to peak you need scope.
                Besides most cheapo multimeter cannot measure Vpp, only RMS at 50/60hz
                  To do proper diagnostic and tuning of metal detector, you MUST have oscilloscope.
                  You can get away without one only if you know what you are doing.
                    you can use another opamp tester more advanced http://www.diod.club/forum/topic.php?forum=1&topic=33
                      I do not have any Hz Coils tx how much voltage should be on the electrodes I have only less than 2 volts
                        Thanks kt315 i not understand in Russia language so sorry Does this measure in the link meet the purpose?
                        http://m.dmmdigitalmultimeter.com/sa...l-tester.html?
                          I suspect your mulrimeter can not handle AC with >10kHz, like dbanner said. Buy one of crazy cheap oscilloscopes DSO 138 or 150. Then you can see, what null actually mean and can measure voltages AC with higher frequencies. Troubleshooting metal detector with poor multimeter is extremely hard task for not skilled electronic enthusiast. How many times I wrote this?
                            Okay am understand it i can Repair it alone thank you for your time and answer me
                              Where can I find a shop that sells good coil for tgsl to Internet online
