Problems with fresh built TGSL
  • #46
    Originally posted by Hyena View Post
    Read TGSL thread, everything is already explained there many times. Only because you are lazy, you expect we will explain it again and again in another new thread about exactly the same topic?
    moderator is patient but sometimes he will blow up!
    • #47
      Perhaps if the search engine was improved so that newer members could find these threads easily instead of bringing forth every thread with the few keywords it lets you use.
      • #48
        In this case, it may be due to a lack of understanding of electronics.
        Who builds such a detector, should know what he does and know the functions of the components and the circuit
        • #49
          i had put this pic 1000th times - no reaction.
          • #50
            Ok kt315 i will react i have tried finding threads for things on here many times and using you search.jpg method it just brings up every thread that has any of the words in normally, i will try that "search titles" only though as had not tried that and THANKYOU perhaps that could be made a "sticky" for noobs as very useful (MODERATORS?)
            • #51
              I PRAY THIS IS THE LAST TIME YOU TOUCH THE RELIGIOUS ASPECT. BECAUSE IT IS VERY EASY TO GO ASTRAY BUT VERY DIFFICULT TO COME BACK. IT IS VERY WISE TO KEEP THE RELIGION OUT OF THIS FORUM. I THANK YOU FOR THE HELP.
              You are not complaining as if this thread is written on Qooran surahs with Holy mantras on your lips
              hard answer eeah?
              • #52
                I HAVE USED THE SEARCH OPTIONS BUT IT THROWS EVERY THREAD AND POST AT YOU. SOME TIME I FEEL THAT TRUE AND EASY INFORMATION IS KEPT ON PURPOSE. THERE IS DIRE NEED TO IMPROVE SEARCH.
                Originally posted by qute1 View Post
                ............ have tried finding threads for things on here many times and using you search.jpg method it just brings up every thread that has any of the words in normally, i will try that "search titles" only though as had not tried that and THANKYOU perhaps that could be made a "sticky" for noobs as very useful (MODERATORS?)
                • #53
                  What if i tell you that you are too **** (i don't know the exact term to denote a miser) to explain everything in ordinary language. Many things are understood when two experts discuss a matter relevant to their expertise but it is a different scenario with novice. I have joined the forum and created the thread for obvious reasons else internet has loads of technical information that i am unable to understand.
                  [QUOTE=Hyena;247043]
                  • #54
                    Originally posted by chuubaba View Post
                    What if i tell you that you are too **** to explain everything in ordinary language instead of complex terminology. Many things are understood when two experts discuss a matter relevant to their expertise but it is a different scenario with novice. I have joined the forum and created the thread for obvious reasons else internet has loads of technical information that i am unable to understand.
                    I am not expert. I am machinist and CATIA designer. I have no additional electronic education. And I am atheist
                    I am not lazy. As I came and had troubles with my first TGSL, I read that thread SEVERAL times. That obvious reason for creating this thread is only your lazyness.
                    And to your question: Does not really matter how you wind your coils. If you get double tone, just swap Rx cables. Even in that thread it is mentioned several times. IT is also mentioned in PDF document...
                    • #55
                      Congratulations for sharing your hard earned knowledge. These nine words solve a problem that i didn't post yet
                      .......If you get double tone, just swap Rx cables.............
                      • #56
                        I hope all these are single side circuits.
                        I made both Tx and Rx coils in clockwise direction. Is this ok?
                        This is your question I answered. Now stop yelling, calling me miser, asking repetitive questions and READ you lazy praying *******!
                        • #57
                          Guys please don't... it does not matter if you offer up your arse to god or not it is the same god leave religion to the clerics or you will both be expelled.
                          • #58
                            This is why Administrator is so important, good thing this forum has very nice and patient wise men to fill that role.
                            • #59
                              Get in Tesoro golden sabre thread and use button "Search thread", you will get only posts in desired thread and I am sure, there are answers for all of your questions.
                              • #60
                                Dbanner can you point out a post where it has been illustrated where exactly an oscillator is located on TGSL and how it is used to measure inductance and frequency of a coil?
