I am trying to remember the Vpp out of the Pre-amp when I got a Null with the correct 20 degree phase shift. I think it was in the 1Vpp range which is perfectly fine.
If you have the correct phase shift at pre-amp out then 1.4Vpp is fine. When metal passes under the coil the amplitude of the RX signal does not change much (for normal 'good' targets) it is the Phase that changes for detection.
Ferrite rejection POT adjustment is very, very touchy. Move the pot too far and SILVER is rejected (not foil).
So use a small piece of ferrite and a silver coin to adjust the GB Pot, ferrite rejected and silver detected. This is done in All Metal Mode.
Then in DISC Mode, increasing the disc pot should reject a small piece of foil (about 1 cm square) then larger piece of foil as the pot is turned, then US Nickle & Pull-tabs.
A big problem comparing test results (your 25cm distance on A coin) is what coin??? The 1 Euro is a standard in Europe but not in the US.
The BEST Air Distance reported in the forum here is 35cm for a 1 Euro but 25cm is more typical. Also remember this is AIR tests which are very different distances than targets in the ground.
