Waltr, what is just happening, I bought a new IC's (U107,U106,U105,U104),I placed them then I turned the device on (without coil) the heating problem is back again (100ohm resistor got so hot) and when I attach the coil and check the negative voltage it was like -1.2v and I also noticed the TR8 is getting so hot (even if I remove the coil but it stil getting hot).
First I just removed the solder from U107 pin8 (I removed the 12v from the IC),well the 100ohm resistor didn't get hot, but the negative voltage still -1.2v and TR8 still getting hot, I removed D6 to disconnect the negative voltage from all ICs,and I removed the coil but TR8 still getting hot, what would cause this?, all the day working on the device
