I really appreciated your help guys, you always give me inspiration to continue working up, I'll not give up until I get it to work, and btw I just purchased the TGSL-EDU from Silver,beside my old project I'll build another one with the edu mod also, btw do you have the 10" DD coil details?
Question about tgsl
Originally posted by ripsdevala View PostDbanner, is there a way to reduce Tx current by pot? need to adapt with high mineral terain
https://i.ibb.co/XkHvRGY/paintastic20200104-124140.png
Hello everyone, I'm just so happy cuz the TGSL-EDU pcb arrived, I couldn't shipping it to my country it wasn't on the list,so I had to shipping it to my cousin in Australia and she sent it to me via Australia registered mail, I'm glad that I got it today.
Anyway I'll start to make it once I get all the components and then I'll post feedback about it
https://i.ibb.co/dpp3D35/20200208-190303.jpg
Originally posted by waleed View PostHello everyone, I'm just so happy cuz the TGSL-EDU pcb arrived, I couldn't shipping it to my country it wasn't on the list,so I had to shipping it to my cousin in Australia and she sent it to me via Australia registered mail, I'm glad that I got it today.
Hello everyone,I just finished soldering everything (all components are new except the ICs from the old pcb) I made the EDU silverdog mod,and then I attached the coil and when I powered up the device it just continue beeping without stopping even when I connect the TX alone but it just continue beepin until I remove the TX coil it stops. I didn't test anything yet because the multimeter with my friend I'll get it soon, but what would cause this problem for now??, I'm really disappointed because it's my second time making this device without success :/
https://i.imgur.com/Dw4reO3.jpg
https://i.imgur.com/cvzOUqc.jpg
https://i.imgur.com/T2STfp8.jpg
You need to go step by step check, as already suggested by waltr and others in previous posts.
Not good to just go and stuff ALL parts.
Pull all the chips.
Connect coil and measure TX oscillator frequency and waveform with your O'scope.
If good install U100 with coil connected. Measure the -5V. Should be -5 to -6.2V for the charge pump..
If either not working then Re-check the Transistor's Pin-Out. Depending on where they were made there can be three different pin-outs.
Once Oscillator & charge pump work install U101 & connect RX coil. Measure with O'scope at U!) pins 7 & 1.
Pin 1 should look like TX, pin 7 should have very low amplitude IF coil is nulled.
Once they work add U102 and check GB and DISC at TR4 & TR5 gates. Then at TR4 &TR5 Source.
Keep adding stages and measure/test. If something doesn't work STOP and find out why, fix it before adding next stage.
Originally posted by waleed View PostThanks guys for the support I'll not give up, and waltr you mean that I remove all ICs only and keep the rest components and then install the ICs one by one and with testing as you mentioned?
Without the IC's those sections of will not do anything.
Originally posted by waltr View PostYes. I also assume you soldered in sockets so easy to pop out the ICs.
