TGSL need advice
  • TGSL need advice
    Hello ,
    I just finished my project,
    on the card I have there is a 4V3 diode
    in addition to the 7808 regulator and a transistor in addition ect ...
    I soldered all the components! I put the circuit
    powered on and it doesn't work!
    do you have any suggestions?
ID:	371619Click image for larger version
Name:	circuit TGSL sans diode zener.JPG
    I attach the diagram and the card model.
    I got the wrong diagrams! here is the good!Click image for larger version
Name:	circuit TGSL avec diode  zener  4V3.JPG
    Oscillator not working?
      Yes, is it oscillating?
      Check on the TX Coil with your O'scope.
      You do have the TX coil connected, right?
        Hello ,
        Nandor and Waltr,
        I don't know if the oscillator is working?
        the two coils are connected! no sound !
        and I have no oscilloscope worthy of this no!
        I only have a small DSO 138 (gadjet)
        tell me how to do? Thank you .
        Yes, something else! I was going to forget about the map that I have, there is
        more components and a 4V3 Zener diode, why?
        what is this diode for? Thank you .
          You have to see why its not working. The oscillator is the heart of this circuit, the 4,3V zenner is for amplitude stabilization.
            Hello, Nandor,
            I have deleted the parts in red on the map! ( see Attachment )
            on the other hand for the moment, I left the sp1 wiring
            when powering up I have a continuous sound !!
            I will soon rewire sp1 (green color )Click image for larger version
Name:	circuit TGSL avec diode  zener  4V3 modifier.jpg
            for the modifications I used the diagrams of the final tgsl rev 3
              There is no negative voltage thats the reason for the continous sound, check the oscillator.
                This is what I looking, for the 4V3 zener is it save to replace with 1N4731A ? 1Watt rated?
                  You can use almost any kind, it will work. The zenner is for amplitude limitation, so the sinewave wont be distorted.
                    Thank You!!
