Hi Guys,
I built the circuit with the instructions in "TGSL Complete Details". I took measurements from the places marked on the diagram
*Speaker not working (no sound)
*TGSL didn't work, I'm waiting for help.
*I used CA3130 instead of TL071.
Note: I also tried TL071, but it didn't work.
*I used 0.40 instead of 0.30 as coil wire.
*I used batteries for the required voltages.
I couldn't include them all due to the photo limit.
In the diagram;
2 = 7.25V
3 = -4.92V
8 = Nothing
11 = 8V
12 = -4.26V
13 = -4.66V
Note: I wrote which section it belongs to as an explanation on the photos. When you enlarge the photo, it appears below, but in black.
Coil Details;
Hantek LCR Meter
10khZ
TX;
Lp= 4.609mH
X= 290 ohm
Q= 27.36
RX;
LP= 5.415mH
X= 340 ohm
Q= 29.82
Coil Wire: 0.40mm
Shield: Not Connected
In the diagram;
2 = 7.25V
3 = -4.92V
8 = Nothing
11 = 8V
12 = -4.26V
13 = -4.66V
Coil Details;
Hantek LCR Meter
10khZ
TX;
Lp= 4.609mH
X= 290 ohm
Q= 27.36
RX;
LP= 5.415mH
X= 340 ohm
Q= 29.82
Coil Wire: 0.40mm
