TGSL - EDU , new boards and kits
    if you had a 4 month child and a woman and you stay the nights with soldering boards instead of sleeping they will become sexy believe me
    they are quiet, they a golden, and if you make allright it makes horny sounds
    p.s.
    all just fun (i would only say it´s good done work by eduardo the forum ApBerg and silverdog and his supplier...)
      anyone else who´s on work with tgsl?
      pics?
        i'm trying to finish tgsl but i stopped the work because i'm waiting for plastic sheets for coil enclosier..now working on original tesoro silver sabre umax board
        best regards
          hello,
          i will try to make a working dd coil this weekend.
          Hope it works.
          I will use 0,28mm enamled copper wire TX 100 turns RX 105 turns.
          Happy winding 1,2,3,4,5..........
          on which hole on the bord i connect the RX start/end and the TX start/end
          i know at the point where tx and rx is printed on but is it important to connect start / end in a special point
          or only that rx and tx are right placed no matter were it starts or end?
          greetings b.m.
            You have attached a picture with the wires , hope its correct.
              thanks,
              i should take a look at the circuit diagramm
              must identify tx j1-1, tx j1-2 and rx j2-1, rx j2-2
                the tx and rx points
                ok i think it should be the right points
                its better to take a look to shematic
                TX2-TX Finish, TX1-TX Start, RX1-RX Finish,RX2-RX Start
                  TGSL runs since two days
                  but the coil making is horrible - got only 20cm for 1€ with my bad produced coil but Disc works ok.
                  Not so easy like Pi coils.
                  Next try coming weekend.
                  i don`t want to buy an origianl coil it should all be selfmade but if anyone in europe can make better coils than me i would buy a one for check and compare with mine.
                  greetings
                    Just finished the main unit half an hour before
                    https://fotoalbum.web.de/gast/bernd.marten2/TGSL
                    hope it can be an idea for others
                      http://www.youtube.com/watch?v=nZvR4KA5jfE
                        selims tgsl coil
                        hello selim
                        you write your coil specs are
                        25cm coil
                        rx:14mH 38ohm
                        tx:6mH 23ohm
                        how many turns did you take for your RX (maybe 160) and which wire diameter is it?
                        Are there any changes on your pcb for the higher resitance of the RX?
                        Are there any others who tried to raise the RX inductance to more than double of TX.
                        Or did my coil not work so good because i have not shielded it for testing.
                        greetings bernte
                          hello selim
                          is it necessary to put in in a metal case and link the shield with it
                          can that be my mistake - that i dont connect any shield to a metal housing
                            Ok, if nobody answers i do it myself.
                            the TGSL works great, but i have ordered a 9*8 5pin web coil (original).
                            I´m not able and i have not the time to make a good working diy coil at the moment.
                            The disc is working PERFECT.
                            I can tune the disc so that it shows a 1 euro coin besides a bottle cap in a distance round 30cm. It is posssible to find a small alu foil piece or disc it out, i can differ between iron, alu, brass etc.
                            just great
                            If i had more time in future i will try a new diy coil.
                            OR somebody on forums sells them in future?
                            but now its time for field testing all my new detectors
                              Can anyone give me info which resistor value i should use for volume control on tgsl.
                              Want to place it in row with +line of audio out to headphone connector plug.
                              thx
                                What is the right way to wire up a tesoro coil
                                I have orange grey purple green and 2bare wires the coil is a 5 pin widescan
