Hello colleagues,
I recently finished the TGSL EDU circuit, i want to measure the tx frequency with my multimeter and don't know where to connect the leads to the circuit. I have build also the coil, my results being 16,5 cm for 2cm bras coin in all metal , in discrimination i do not have any detection, neither iron or other metals. My tx coil is 6.15 mh and rx is 6.55 mh (105 for tx and 110 for rx whit 25.3 and 26.1 ohms) Another thing that noticed is when the sensibility is more then 50% ,it stars to make "beep beep, beep continously an sometime this happens after a test target is waved over the coil) I hope to find the fault , thanks in advance.
Soverey.
Soverey.
