PICS OF MY TGSL LOW RESOLUTION
  • PICS OF MY TGSL LOW RESOLUTION
    HELLO , pics of my tgsl in low resolution .
    looks the buiness well done
      thank you everything was done by hand. I must now finish the head to adjust the nulling and then put the resin epoxy
        what is a TGSL detector ???? is it a tesoro ???
          TGSL stands for "Tesoro Golden Sabre Light".
            can i use a coil ment for a tesoro bandido micro max with this TGSL detector ????
              no , bandido work 10 khz and TGSL work 14 khz
                so what tesoro coils will work with a TGSL ????
                  If the coil has a 5-pin plug, then the answer is yes. The Tesoro coils with 4-pin plug have different inductances.
                  I think the uMax uses a 5-pin plug, so it should work just fine with the TGSL. The actual TX frequency is not important for these coils.
                    ok , thanks Qiaozhi it is good to know
                      Qiaozhi is correct , I used the web coil and the solid which were 5 pin types the inductances were slightly different between the two but you can alter your CX capacitors to suit.
                      The golden rule with the TGSL coil is the .5MH between the TX and RX , for instance 5.9/6.4MH is a typical manufacture inductance value for the Tesoro coil or as we have made on here 6/6.5MH.
                      if you stray from those inductances you can play with CX to compensate but nulling and end results are disaponting.
                      Will put my hands up on this one I went through dozens of coils in the early days till getting it right in the end I bought manufactures coil to copy.
