TGSL 2 tones ID for V3 SB not for EDU
  • TGSL 2 tones ID for V3 SB not for EDU
    hello friends, this night I worked a little to make compatible the small map for multi-tonal TGSL SB V3. therefore not considered in EDU version. I made a PDF file that includes all the materials necessary for making the pcb, and wiring.
    multi-ton TGSL-V3.pdf
    thank you to tell me if it works properly for those who try to change their detector. I will try next week.
    Anyone work on this working?
      news ?
        Bad news...
          Hello, today I did the pcb and was wired it when I warned that the image of the wiring is not of the TGSL V3 but of the Tgsl of Edu. Also show components to be removed in the TGSL V3 which can then be seen in the wired image. For the doubts I will be based on the modified schematic.
