Mobile Phone Interface for Audio, Visuals and Control
  • Mobile Phone Interface for Audio, Visuals and Control
    This is a web-based 'javascript' application for audio and visuals onto your phone.
    eg it is a single html document that will work on any device.
    It is a work in progress
    Check it out working here:
    www. tctec . net / wombat.html
    The 'Demo' mode, simulates targets.
    Purpose:
    Demonstrates responsive audio on the mobile device so wireless headphones can be used.
    Use the Mobile device to display and control the detector.​
    More detail:
    Communicates to your detector over a Wifi interface , not too expensive now with something like a 'ESP8266' module for $13
    Audio is fully adjustable and customisable: waveform, frequency and range
    It can be daunting to cobble together javascript and web applications, especially when you have no experience with coding
    so I will give you free and unlimited support and help from one of the best developers in the world today, he also knows alot about most things,
    he's called 'chat gpt'
    System overview:
    I am making a web-site for this project
    Main points:
    • Audio is ok through the phone jack.
    • Bluetooth headphones from the phone is too laggy to be usable (0.5 second delay) .
    • ESP8266 (wife module) has simple (arduino) software that is just a serial bridge between the arduino nano and the phone. (attached)
    • The html-JavaScript application on the phone is quite easy to develop with free tools: notepad++ and chromium-browser. Code changes can be instantly tested and debugged with the 'inspect' built into the browser.
    • Visuals updates on the page must be kept to a minimum for speed.
    • Capable of 10Hz update of two separate audio wave forms (one for conductivity sound) .
    • Sending 3 x 32bit integer values from the Nano to the phone 10 times per second no problem.
    • The Wifi module is power hungry, and a source of noise so it has a separate DC-DC converter power supply ~(60mA at 12V).
    • The Front-end detector electronics should be put in a metal can or shielded /kept away and spurious noise that may spit out from the Wifi module, if precautions are taken then it is ok.
    Attached is a working html application, and the ESP8266 arduino code
      Hi Tec,
      One question - what parameters of metal detector you improve with these additional features?
        Hi, good question;
        Audio over Wifi can be laggy and is not as good as direct Wired headphones or low-latency wireless.
        The Wifi Link is for: Visual Display, Data analysis and Custom control
        For example the charts below are made using free 'html and javascript' tools.
        So what do I get ?
        1. Coil setup: I want to know exactly what my coil signal looks like and set the perfect sample delay (see below)
        2. Target Analysis. I would like to know what my target is before I dig it up. Is this possible ? This is research into plotting the sample at ~15uSec against the sample at ~40uSec as the coil is swept over the target.
