Despite all the problems that this project has had, the basic design is really very good. Using the Magenta PIC code it was an acceptable detector. Mark Paul suggested revisions that would have made this design a real killer. Unfortunately the .asm file commented in dansk would assemble a hex file that would operate (with some difficulty) but would not save to eeprom. With a lot of help from Maxime Thibault to sort out the code and improve it and a few modifications to the scematic this project is a go. It will allow real time changes to Pulse width, Pulse repetition rate, Sample width and Sample delay. Then it will store these parameters in 4 stores for recall. (Four setups for four coils?) I intend to incorporate an LCD oscilloscope ($39.00 ebay) This will facilitate in the field setup to optomise operation. Mods are needed to prevent the mosfet from conducting before the PIC is operating as this causes excessive current. Those who have failed to have the PIC code as previous work at all, need to know that without mods the coil should be disconnected at startup. Further the PIC at first startup has not stored the parameters in eeprom. It will give an excessive pulse width. You must start first time with micro-switch 4 closed to store these values. Most of the previously provided firmware will operate this way. Those (FIRMLY) interested can contact me for upgrades as they occur. This was a good design bedeviled by corporate greed and poor programming skills from builders.
Eric.
Eric.
