The correct coil for silverdog surf pi 1.2
  • The correct coil for silverdog surf pi 1.2
    Hello everyone, I am building the silverdog surf pi 1.2 , I would like to build 2 coils, one 10 "and one 8", I have 0.51 mm enamelled copper wire available. around I read that a correct coil should be between 350-400 uh (confirmed?) and in the instructions I found they recommend about 20 turns of wire for a dimeter of about 23 cm. Do any of you know the original white's plate what inductance does it have? Sorry for my don't perfect english ......
    Best regards from Sicily
    You are on the right way.
    I managed inductance of about 330uH for Surf-PI and for some other PI projects too.
    Wish you all success.
      in real life we do 'BASKET' or 'FAST' or 'FASTEST' coil. this forum has good advanced SEARCH engine. use it.
        my idea was to 3D print a round support where to test various windings ..... as soon as I find what satisfies me, I create the mold of the plate with the 3d printer, I put it inside the support and the waterproof cable gland and close everything with thermal shock resistant nautical resin
          I have an original Surfmaster coil - it measured 254uH on my meter
            hello silverdog, this component list its correct?
            ID Name Designator Footprint Quantity
            43 220k R17 AXIAL-0.1 1
            30 47k R22 AXIAL-0.3 1
            31 100k R35 AXIAL-0.3 1
            32 33 R34 AXIAL-0.3 1
            33 100k R1,R18,R23 AXIAL-0.1 3
            34 3.3k R2 AXIAL-0.1 1
            35 100 R4,R5 AXIAL-0.1 2
            36 15k R25 AXIAL-0.1 1
            37 10k R12 AXIAL-0.1 1
            38 1k R14,R13,R21 AXIAL-0.1 3
            28 220k R15,R16 AXIAL-0.3 2
            24 51k R26,R29 AXIAL-0.3 2
            25 240k R28 AXIAL-0.3 1
            16 1M R9 AXIAL-0.3 1
            17 22k R11,R20 AXIAL-0.3 2
            13 390 1/2w R6 AXIAL-0.3 1
            7 1k R3,R7,R8 AXIAL-0.3 3
            39 100K Delay P3 potenziometro 1
            40 100K Offset P1 TRIMMER_VISHAY_64W 1
            41 10K Tuning P2 potenziometro 1
            42 1K Volume P4 potenziometro+switch 1
            3 1N4001 D6 DO-41 1
            14 1N4148 D1,D2,D3 DO-35 3
            11 1000uF 25v C2 CAP-D10.0XF5.0 1
            5 220uF 25v C13,C14,C15 CAP-D5.0XF2.0 3
            19 1nF C9,C17,C10,C11,C12 0.01uF, 63V Capacitor copy 5
            29 470nF C5,C6,C7 0.01uF, 63V Capacitor copy 3
            22 100nF C16 0.01uF, 63V Capacitor copy 1
            18 100nF C3,C4,C18,C8 0.01uF, 63V Capacitor copy 4
            9 22nF C1 0.01uF, 63V Capacitor copy 1
            26 LM358N U3 DIP8 1
            21 MC14093B U4 DIP14 1
            20 CD4066 U7 DIP14 1
            15 NE5534 U2 DIP-8 1
            8 TLC555 U1 DIP-8 1
            6 ICL7660 U6 DIP-8 1
            4 78L05 U5 TO-92(TO-92-3) 1
            27 MPSA13 Q6 TO-92(TO-92-3) 1
            23 IRF9640 Q2 TO-220(TO-220-3) 1
            10 2N3906 Q1 TO-92(TO-92-3) 1
            1 BAT BATTERY HDR-1X2/2.54 1
            2 SW1 SWITCH HDR-1X2/2.54 1
            12 Coil L1 HDR-1X2/2.54 1
            and i have pcb marked surf pi 1.2 and not surf pi 1.2 apb, there are differents?
            thank you
              No difference between 12. APB and 1.2
              Partslist attachedsurfpiparts.txt
                Hello silverdog, in the pcb there are 2 point signed TP1 and TP2 (near delay trimmer) what function do they have? another question, IS possible add a button for no motion mode/pinpoint in this circuit? i have just build a prototipe coil, 10" monoloop 260uH and 1,5 ohm without cable coil.......
