TMPI coil #5
I know it is going to take a few coils for trial an error, to come up with the final coil. Therefore I wind and assemble the coils in a temporary manner, to be tested, before casting a final coil.
I also try to use ordinary wire and make the whole thing as simple as possible at the beginning. Once the right compromises have been found and the coil sensitivity is within acceptable limits, further refining can be done.
I think the coil #5 has reached acceptable limits. Here are the specs:
TX, OD 45cm, 16 turns of #20 AWG magnet wire.
RX, OD 22.5cm, 20 turns of #26 AWG magnet wire, center tapped.
Bucking coil, 4 turns of #20 AWG magnet wire, wound around the RX coil.
The cable is 2m long so that I can place the coil at some distance from the scope and breadboard. I use CAT 5 cable because I need at least 6 legs.
Since the CAT5 cable has 8 legs, I parallel the spare legs for the TX to reduce the resistance.
I end up with a total resistance (coils, cable and Mosfet) of about 2 Ohm for the TX.
With the pulse at 127uS and the TX voltage at 15, this gives a max TX pulse of about 4A.
For the testing I do not make a full shield, but I clamped the coil assembly between 2 sheets of Polypropylene "cardboard" that have been coated on one side with a graphite compound. A drain wire is embedded and connected to the ground.
The center tap is connected to the ground.
The wires are:
1+2, TX out
3+4, TX in
5 bucking coil current control
6 RX+
7 RX-
8 Ground
When I run the TX, and directly sample the input and then amplify it 15 times, I can see the response of the targets on the scope.
The smallest target that I can pick up right on the coil, is the 20mm diameter
on side copper PCB disk that I cut out. Unfortunately I don't know what the exact thickness of the copper is.
This minimum target gives me a 1.5mV signal at the center of the coil.
since this signal is amplified by 15, the actual signal response is 0.0001V or 100uV.
Is this good enough? Feedback and comments are welcome.
Considering, the basics of the coil are good enough, what can be improved?
The bare magnet wire produces quite a bit of inter-wire capacitance. Teflon coated wire puts a bit more space between the copper, so the capacitance is less.
Also I ended up with a about 2 Ohm of total resistance. Reducing the resistance would improve the efficiency and increase the TX pulse Amps.
Using several wires in parallel for the TX coil winding, for example 4 times #22AWG, would reduce the wire resistance by half and reduce the capacitance too. Again, Teflon would be very good, but as some of my earlier tests have shown, adding a Polypropylene string as spacer between the wires
reduces the inter-wire capacitance dramatically.
The coil cable: Seeing that the CAT5 cable is working quite OK, I would recommend shielded CAT6 cable that has AWG#22 wire instead of AWG#24
like CAT5.
The shielding of course should be done around each coil bundle, but with at least a 5mm spacer between the shield and the wire bundle.
The graphite compound seems to be doing a very good job, so I recommend it.
Tinkerer
The wires are:
1+2, TX out
3+4, TX in
6 RX+
7 RX-
8 Ground
like CAT5.
Tinkerer
