Universal PI Micro
  • Originally posted by matabele View Post
    Yep - live not too far from there, where the 'goway' birds cry.
    PI metal detectors generally record 3 channels - each corresponding to an integral of the response over a certain period (channel) after different delays. One is generally a ground balance - the other two are on either side of the 'knee' in the response signal.
    The problem is that ground and target responses are highly variable - the trick is to 'tune' the instrument to separate the target response from the ground signal in the presence of noise for the particular conditions encountered. This can not be done in the general case, as conditions vary tremendously (hence the 'salt', 'deep' etc. settings on many instruments.)
    An instrument which records the entire decay curve could be customised by the user to match the specific conditions encountered - the whole response being compared to a ground response for the particular location and coil used.
    With the TINKERERS_V1, I have been using 4 different samples, placed at strategic points in time.
    http://www.geotech1.com/forums/forumdisplay.php?f=53
    This is working well and gives good discrimination.
    I would like to improve on that method and extract 10 or even 20 samples in quick succession to capture a whole time section.
    The reason for this can be better explained when you look at the pictures at:
    http://www.geotech1.com/forums/showthread.php?t=15441
    Where I try to show that there is a lot of information available, if one knows where to look for it.
    When locking at the oscilloscope screen, I can see movement at certain spots in time that indicate the TC of the target and if it is iron or non magnetic metal. Sampling at these spots let's me extract this information.
    This information has thought me how to produce a TX pulse of a different shape, that gives more information about the target, because it excites core eddy currents not only skin effect eddy currents.
    I believe that if this is taken a step further, like you indicate, recording a significant section of the decay curve, much more information can be extracted and much better compensation for mineralized ground and other PI problems could be designed.
    Unfortunately, I am not capable of doing the programming. Are you?
    Tinkerer
    • Time Domain Detector
      Until recently, it was not possible to build a time domain instrument at reasonable cost, as this requires a dynamic range exceeding 100dB. Most multichannel instruments, therefore, resorted to multi discreet channel or swept frequency techniques in the frequency domain.
      I believe that it is now possible to build a quality time domain instrument with off the shelf components - however, many difficulties must be overcome. For example your current IB instrument does not appear to receive a classic time domain response (which should resemble an exponential decay curve.)
      There are several problems to be addressed in order to increase the bandwidth (dynamic range.) Early stage sampling corresponds to higher frequencies, late stage sampling to lower frequency:
      Using a digitiser for TD measurements
      For small shallow targets we require fast switch off for early stage sampling, and for larger deeper targets we need better resolution in the late stage. This requires work on a broad band receiver loop, with low noise preamp, something the ELF community have been doing for some time.
      To 'tune' the response it is also possible to transmit a wave rich in the frequencies of interest rather than a square wave. There are two approaches to this:
      - either use a FPGA to create an arbitrary waveform generator - something like this
      - or (my preference) - to use a PWM to create the desired wave somewhat in the fashion of magic sinewaves. A couple more links about how to do this yourself.
      http://en.wikipedia.org/wiki/User:Kieff/Sine_from_square_waves
      http://massmind.org/techref/io/pwm/harmonic.htm
      Finally, we need to work on the uC. My preference is to piggyback on the robotics community, and use either an Arduino, or my preference the Pinguino. This will cut down development time, and enable additional tinkerers to get involved!
      Hope the links stimulate some ideas.
      • Preamplifier
        Looking through some reference material, it would appear that the response from your receiver coil resembles the voltage response shown for the loop on this link:http://www.vlf.it/minimal2/minimal2.html
        The article explains why a preamp functioning as a current to voltage amplifier is better in these circumstances than a voltage amplifier. Some additional theory can be found here
        A realisation of this circuit using an OP27 is here and one based upon an LT1028 is here.
        It may also be possible to build a satisfactory (and cheaper) current to voltage input preamp utilising an OPA134 or perhaps even a NE5532.
        • SD2000 front end
          The current mirror (LM394) at the front end of the SD2000 perhaps does the same thing?
            Thanks for the many interesting links and information. It will take me some time to look at all that.
            The "Pinguino" sounds interesting.
            If we can combine intrinsic metal detector knowledge, with digital programming, we will end up with something very useful.
            Team work can get us there.
            Tinkerer
            • hi
              Originally posted by elbombaci View Post
              Hi to all
              This links is my projects viedos.
              http://video.google.com/videoplay?do...28985205264269
              http://video.google.com/videoplay?do...07037523843742
              @bugwhiskers
              Thank you for explanation.
              hi
              can you pleas publis your project step by step in order to make it usefull to us
              i will be thankfull
              • hi
                I KNOW THAT I'M NOT ALLOWED TO TALK ABOUT THE PROJECT NOR TO SAY ANY COMMENT BECOUSE WE ARE ONLY WAYTING FOR THWE PROJECT TO END UP
                I'M SORRY
                I DONT KNOW HOW CAN I BE HELPFULL TO THIS FORUM I AM STUDING MICROCONTROLER SINCE 2 YEARS BUT WHAT YOU ARE DOING IS THE FIRST TIME THAT I'M HEARING ABOUT
                SO I WANT TO KNOW WHAT HAPPENDTO THE PROJECT IS IT COMPLETED NOW OR WE HAVE SOME TROUBELS IN DISCRIM ....
                THANK YOU ALL I APPRICIATE THE WORK YOU HAVE DONE
                TC
                DANNY
                • Originally posted by danny475bek View Post
                  I'M SORRY
                  TC
                  DANNY
                  Danny. probably it will be commercialized. As far I know project still in development / testing phase.
                  • Hi bugwhiskers,
                    New in the forun,i'll would like ask some questions about the UPIM,i don't want squeeze you like a leemon but your help is important,i know electronics like a hobby,i can't calcul anything about it;do you have a mother board with the atmega?best regards.
                    • Hi elbombaci,
                      New on the forun,i'm in France,i want to ask you if you can help me about the UPIM,i asked to bugwhiskers :no reply;thank and best regards.
                      • Return Bugwhisker
                        I read this post on UPIM and was on the verge of owning & committing myself to the very good DIY but hopes crashed as Master Bugwhisker took a leave. Tried googling around and found a link - but alas that was under some kind of cloud firewall "Incapsula" <http://www.google.co.in/url?sa=t&rct=j&q=upim+bugwiskers&source=web&cd=1&v ed=0CEAQFjAA&url=http%3A%2F%2Faustralianelectronic goldprospectingforum.com%2Fbasic-questions-forum%2Fupim%2F%3Fwap2&ei=Uqu8T--HHMi8rAeZgMGjDQ&usg=AFQjCNEpy-LfQudZQJfqwc7eH8gbpGgu_Q&cad=rja> at least from India - maybe the thread shall be aggregrated and closed for further requests. Maybe with whatever has been left scattered - someone "GURU" like - can take it to final conclusion in the same open-source spirit.
                        • Wow. Three astonishing designs sunk without trace, thanks to the gutless jackal commenters (most of whom smelled much like metal detector competitors, IMHO).
                          At least I've learned some amazing things, so thanks, bugwhispers, I'm so pleased to have been able to learn as much as I did. Much appreciated!
                          As an ex-Rat boy, I was happy to learn from another!
                          Cheers,
                          Pete
                          • Originally posted by Pete the Builder View Post
                            Cheers,
                            Pete
                            Bugwhiskers is still active with the MC QED but i think will now only post on my forum. Your comments are spot on!
                            dougAEGPF
                            • I have to admit, even with my background, I was...er...surprised? dismayed? embarrassed?... to see cartoons in an otherwise technically fascinating thread. Or maybe they were intended as genuine fun. The missus didn't think so, though, and she's much better tuned than I am. Ah well.
                              Thanks, guys, for keeping the thread available. It was interesting to see this approach develop, even though it's been superseded.
                              Cheers,
                              Pete
                              • I didn't recall the cartoons, and surprised that I had not deleted them already. Rectified.
