I just have to say this is excellent what you guys are accomplishing. I wish I had kept up with my signal processing theory so I could start doing some of these experiments and better follow your discussion.
What you are doing with laptops is the exactly right approach for developing metal detectors, whether you use all analog, DSP, or laptop computer. You are understanding the information which will guide all designs you may make.
When I was playing with metal detector circuits (very simple), I had thermal and 1/f noise problems in op amps, it was very low frequency just like target and ground signal when sweeping the coil. I had an idea to use a quad op amp and measure the thermal noise from one of the unused amps (grounded input) hoping that it would be correlated with the other op amps that were amplifying the signal. But I never had time to try it, just wondering if that might help.
I had a question about the high-Q TX coil design -- when you put it near the ground, wouldn't the ground make much lower Q? Maybe it doesn't matter.
I will try to understand this discussion, I think it is very important to any MD design. Thanks for sharing all the ideas and results!
-S
-S
