Let's make a PC-based metal detector with usb interface!!!
AZIZ, YOU KNOW YOU GAVE ME AN IDEA WHEN YOU MENTIONED HEAD-PHONES!!! THE COMPANY CALLED DETECTOR PRO WHO MAKES HEADHUNTER LAND PRO AND ALSO PULSE DETECTOR'S , THEY PUT ALL THE ELECTRONICS IN THE HEAD-PHONES. SOME DETECTOR COMPANIES PUT SOME ELECTRONICS IN THE SEARCH COIL BEFORE IT GOES UP THROUGH THE COAX CABLE TO THE HOUSING. LESS NOISE WILL BE RIGHT AT THE SEARCH-COIL........ AZIZ, HAVE YOU DECIDED WHERE YOUR RX AND TX CIRCUITS WILL BE ???? EUGENE
