    If current flows through the inductor, it stores energy. If you don't dissipate or recover the magnetic energy, what would happen at switch-off? If you burn the energy, the efficiency decreases.
    What I'm thinking is that for charging the capacitor, just put an inductor in series with the battery and close the switch. Then you have a one-cycle buck/boost sort of: the inductor will store the energy while the current flows into the discharged capacitor, so you don't lose the energy due to I * dV in the battery internal resistance or wire resistance. When you turn off the charging switch, the remaining energy in the inductor goes into the capacitor (need a shunt diode as usual), finishing the charge. So it is just more efficient than charging the cap directly from the battery. A buck-boost regulator does the same thing really, but uses many cycles to do it.
    So I'm wondering if a simple series inductor makes a simple solution instead of a whole SMPS.
    See what I mean?
    -SB
    • Hi simonbaker,
      See what I mean?
      -SB
      I am already using a synchronized one-cycle buck conversion with faster discharge timing and enhanced efficiency (compared to usual buck converter with diode but without the synchronous rectification). It is of course operated in discontinous mode. No PWM generation and regulator necessary for this. Just a flip-flop, comparator, mosfet-driver, reference voltage, mosfet and a coil. It is already the simplest and cheapest implementation.
      Interestingly, the regulation is accurate enough (I got a regulation of <5mV ripple at 10V source ripple). The source voltage would not ripple at such voltage levels of course. The post regulation is probably an overkill but could make the regulator superb (µV regulation).
      The chip manufacturer of SMPS regulators don't see the importance of having a synch input pin. The existing regulators with synch input pin and desired specification are unfortunately not available to me. So a discrete solution makes the circuit complexity high.
      I need to wire up the solution to see, if it meets my desired specification limits.
        Hi simonbaker,
        It's going to be a heck of a platform when you're done Aziz. Great stuff...
        -SB
        • Hi all,
          there is sometime a much simpler solution of a big problem. One sometime don't see the obvious solution. Shame on me.
          I have now a very fine solution of the regulation, which will meet hopefully the desired accuracy. Transformer principles will solve my big problem. During charging of the capacitor bank, the transformer stores the magnetic energy. After reaching the desired voltage, the regulator will switch off charging. The stored magnetic energy in the transformer will be discharged on a secondary winding back to the source (back to bypass cap). As the primary and secondary windings are not galvanic coupled, the right polarity can be set to feed the energy back. A snubber circuit is necessary, to damp the minimum energy, which can not be transferred through the diode (due to diodes forward voltage). The secondary windings could be higher than the primary windings to improve the efficiency of the back transforming process.
          It now get's very simple.
            Hi all,
            Can you show a schematic of the interesting idea?
            -SB
              -SB
              It's too early to show something. It is not finished yet. But the principle is really very easy to understand and to implement.
              The capacitors get charged faster now as the magnetic field energy discharge path is decoupled from the regulated coil voltage.
              • Hi all,
                still working on the coil power regulator. The switching speed is critical and I am trying different configurations to get out better performance. An ultra-fast voltage comparator like the LT1016 (10 ns) would be surely an overkill. The LM311 should do the job as well (200 ns). The mosfet driver has also switch-off delay and fall-times. Finally the mosfet switching times will add to the system delay. The n-mos fets should switch-off faster due to lower gate capacitance.
                I did a discrete high side p-mosfet driver, which works well at the expense of more parts. Now I am thinking of changing it to a n-mosfet high side type. There are lots of high side mosfet drivers available. Interestingly not much for p-mosfets.
                High side n-mosfet driver (spice simulation results using LTC4440):
                The switch-off current is unfortunately not abrupt due to boost capacitor (bootstrapping configuration) of the mosfet driver.
                The p-mosfet version shows slightly better results but the higher switching resistance will reduce the overall efficiency.
                I probably will try the high side n-mosfet version. Now looking for an available part (LTC4440 is not available to me).
                • PS: I can get now a power supply rejection ratio of 68 dB at least (< 1mV ripple).
                  • Simple Buck Converter Principle
                    Hi all,
                    below is the discussed very simple buck converter principle. It has up to 92% peak power efficiency. The mosfet driver and the switching logic (flip-flop, comparator, etc. ) is not shown here. The coil is a typical transformer wound on a ring core ferrite.
                    I probably will use the LM319 dual voltage comparator as it is fast enough (80 ns), cheap and easy to get. The most delay comes from the mosfet driver and mosfet itself. A switch-off response of 250 ns and less should be possible. Switch-on characteristics is not critical and can even be much higher (1-2µs).
                    I have not finished the full schematics yet and I am considering to use the buck converter also for the power supply section to maximize the power efficiency further. I hope to get a wide input voltage range (9 .. 28V).
                    • Voltages and currents (see below):
                      • High-side nch-mosfet or pch-mosfet driver?
                        Hi friends,
                        regarding the coil power controller:
                        I have reduced the switch-off time down to 170ns (with p-ch mosfet Si4401DY having 37 nC gate charge). Following dumb calculation: 80ns comparator + 20 ns flip-flop + 70 ns mosfet-driver and mosfet switch-off. It was a discrete high-side p-ch mosfet driver with fast switch-off optimisation (3A switch-off peak current!).
                        Generally, the high-side n-mos drivers operated in bootstrapping mode won't cut off the switch current instantly and the coil power supply is capacitively coupled to the driver. I have tested the LTC4440 in the circuit simulation and it hasn't the benefit compared to the discrete p-mos solution.
                        So a high-side p-mos driver is most convenient for this application. Nevertheless, low-side drivers can still be used in the high-side configuration. Indeed, I have several MCP1407 (6A mosfet driver), which I would like to use it. The logic input signal must be level shifted up to the high side and a high-side gate power supply is necessary, if I want to go down to 9V input voltage. Due to the lower input voltage of 9V, the mosfet gate voltage is limitted to 12V or 15V (not anymore 18V). A charge pump inverter will support the switch-on of the p-ch mosfet with negative voltage converter.
                        The high-side power supply for the mosfet gate driver is critical and must be stable enough (have to float with the input voltage). I will use either the 79L12 (-12V) or a discrete -15V solution or even a low-drop negative regulator. This will ensure same gate voltage drive even the battery voltage diminishes or changes over time.
                        Input voltage: min. 9V, negative charge pump could deliver -7V: Total span: 9+7=16V. This should be high enough for the 79L12.
                        Using low input voltage and high gate drive voltage makes an own power supply for the mosfet driver necessary. Fortunatelly, these circuits need not much power and we can use linear regulators. We also need it anyway to regulate the main power supply. Most power draining parts will be efficient down converted.
                        So I have to change the power supply section completely to be efficient enough and make a wide input voltage range possible (9V .. 28V) . It will very likely the most complex part of the detector.
                        • Hi again,
                          damn, the 78xx/79xx withstand up to 35V but have a 2V voltage drop. The low-drop types will operate up to 30V or even less. So I have to choose the right part carefully.
                          I will introduce a 8V (or 8.5V) system voltage and this two times. One for low power part (helper power supply for regulators) and one for stepped down regulation (main power supply). The system voltage will produce all necessary voltage levels (inverters, up-converters, mosfet drivers, etc. ) . With low-drop out regulators, 8V can be regulated with minimum 9V input voltage. I have choosen 8V and not 5 or 6V due to high gate drive voltage and the flexibility of using standard 78L05/79L05 regulators.
                          So only a span of 8V - 5V = 3V will be heated up.
                          A comparison:
                          Input voltage: 15V
                          Drain current: lets take 200mA @ 5V (electronics part only, coil supply not included)
                          Buck converter efficiency: 85%
                          If we use linear regulator, the voltage difference of 15V-5V = 10V will be heated up (10V*0.2A = 2W loss)
                          With the 8V system voltage:
                          Loss: (8V-5V)*0.2A = 0.6W
                          Taking efficiency of 85% into account (buck conversion): 0.6W*1.15 = 0.7 W loss
                          Now make the calculation, if we have more current drain (400 mA) and 25V input voltage!
                          Linear regulator loss: 20V*0.4A = 8W
                          Buck conversion loss: 3V*0.4A*1.15 = 1.4W
                          That's the difference with high input voltages.
                          • F$!%$!§$& The 78xx/79xx are driving me crazy .
                            I want to have high input voltage possibility at any cost (up to 28V)! But getting closer to the absolute maximum ratings (input voltage), the regulators won't work well. So I can not go with the input voltage up with the 79xx regulator. The DC-DC charge pump can deliver max. -8V (-7V regular). The 79xx has -35V maximum input voltage range. There is also some span necessary to get this regulator work well (lets take max. 27V limit according to recommended operating conditions mentioned in the data sheet).
                            The max. input voltage would be:
                            Vinmax = 27V + (-8V) = 19V
                            That is definitely too low.
                            Ok, there are other options:
                            1. Using the LM337 regulator (up to -40V)
                            2. Discrete solution (up to -40V)
                            I have choosen the discrete solution. It makes marvelous precise, low power consumption, low noise high-side regulator possible. Have a look into the floating gate voltage (below). I probably can go with the input voltage even higher than 28V.
                            • Forgot the upper limit input voltage behaviour:
                              • Project News
                                I have some bad and some good news.
                                Bad news first:
                                I am sorry, but I have no money for the PI controller at the moment. The PI controller project is frozen again. You know, I don't like to ask someone for money. Maybe I should think of accepting donations to this project. But you can be sure, I am not going to work for the krauts to earn some money. Even then not, if the hell has got frozen over!
                                Nevertheless, I had some time to make some progress. Big thank you to Tinkerer. He fortunately has re-invented some good old ideas, which made the progress possible.
                                Good news:
                                There is an improved simple solution to make a pulse induction detector (PI) in an induction balanced (IB) coil configuration possible. This one does not operate in resonant mode (like VLF) and hence can detect more features about the target. It offers a good discrimination. A 100% save discrimination is not possible (I have the preliminary proof of the fact).
                                Here are some facts about the solution:
                                - offers very high power efficiency (low battery drain, TX pulse energy will be efficiently recycled)
                                - high pulse currents (powerfull magnetic field pulses)
                                - better target stimulation (large and deep targets gets stimulated better)
                                - high depth performance (1 EUR coin detected at 40-48 cm, air-test)
                                - good iron discrimination
                                - simple and cheap circuit implementation (no MCU/µC)
                                - two box coils also possible (should perform even better)
                                - adjustable pulse power, pulse frequency and pulse operation mode
                                - can even be used for geological explorations (big loops)
                                What you need:
                                - Hardware board (circuit not finished yet), coil, battery (12 V)
                                - Netbook/Laptop
                                - External USB sound card (24 Bit/96 kHz, others should also perform well with reduced sensitivity)
                                - Windows based software (to be implemented)
                                The software part will do all the things required for the operation:
                                - pulse timing, pulse width, synchronisation, pulse operation mode (all with stereo line output: left/right output channel)
                                - frequency domain analysis (FFT/Lock-in amplifier/Goertzel algorithm)
                                - signal analysis and feature extraction (discrimination, filtering, ground balancing, ..)
                                - detection signalling (sound output in the internal sound card of the netbook)
                                The hardware part will consist of:
                                - power supply part (+5V, -5V, +12V mosfet driver)
                                - clock/synch detector (timings)
                                - transmit driver part (mosfet driver, coil driver)
                                - receiver amplifier (either single ended or differential)
                                That's all. The hardware part will be the simplest one. The most difficult part will be the software part.
                                The sensitivity is really extremely high. So the coil design might limit its performance due to critical requirements using induction balance principles. The 1 EUR coin detection example should still make a very reliable detection at 30 cm possible. But the most benefit should be a more realiable discrimination and easy operation.
                                The receiver signal will be continiously sampled and processed. There is no gating or multiplexing required. All target signals are buried in the frequency domain (FD). If the pulse frequency is f0, all n*f0 frequencies will be decoded using digital signal analysis methods (FFT/Lock-in amplifier/Goertzel algorithm, ...). The reactive and resistive target response can be extracted from the frequency domain response. The ground balancing should also be trivial with proper software coding.
                                n is going from 1 to x. X is limitted by the max. sampling frequency. A range for f0 is from 750 Hz to 3 kHz.
                                That's all for the moment. There is still huge work to do. I will provide the basic hardware part of course. I even do not have the software so I have to write the software part yet. All experiments were done with the experimental software, which is now in a very very bad state (quick & dirty hacks).
                                Here are further readings, on which the coil transmitter is based on:
                                http://www.zonge.com/PDF_Papers/TEMposterAs.pdf
                                http://www.google.com/patents/about?id=3ik1AAAAEBAJ&dq=US+4157579
                                The patent US4157579 is already expired and I am going to use only unipolar magnetic pulses for simplicity (bipolar in the patent application).
                                And have a look at the Tinkerer's IB-PI project. He is using the same principles. So we have to thank to Tinkerer for making this solution easy and possible.
                                http://www.geotech1.com/forums/showthread.php?t=15683
                                Have a look at capacitor C9 (1µ)!!! Drop the damping resistor R10 (1k), the snubber resistors R24 (420) and R25 (100). And we have the basic powerful coil transmitter.
                                Let's continue with this project until I have some money for the PI controller. To be continued ..
