PC-base Conductivity Meter for Geophysical survey
  • PC-base Conductivity Meter for Geophysical survey
    first I am sorry if my english is not very good
    I wish with your helping, we can made a new PC-based Conductivity Meter for Geophysical survey using soind card, this Conductivity Meter will can operate with pc or laptop very well and measuring ground conductivity by elctro-magnetic (em) methods with some nice advantages, such as exact saving datta... its like the project of aziz (Let's made a PC-base metal detector with usb interface !!!)
    Electromagnetic Techniques
    Fixed Frequency Electromagnetic (EM) Profiling
    OUTLINE
    This is an active method that uses an electromagnetic (EM) signal to detect variations in subsurface conductivity. The EM signal is generated by a transmitter coil from where it radiates into the ground generating eddy currents within any subsurface conductors. These produce a secondary EM signal that is detected on surface by a receiver coil. The spacing between the coils determines the maximum depth of investigation in any given setting. Instruments commonly used in environmental and engineering applications are capable of site investigation to depths of between 1-30m. However, target resolution varies inversely with depth.
    DETAIL
    Electromagnetic profiling utilises a time-varying electromagnetic field (the primary field) to induce eddy currents within subsurface conductors. These currents result in a secondary magnetic field that is measured together with the original transmitted signal, using a receiver coil on the EM instrument. The secondary field is then separated into two orthogonal components, the real and imaginary (quadrature) components, representing respectively the vector components of the field in-phase and 90 degrees out of phase with the primary. The quadrature component provides a measure of the apparent ground conductivity whilst the real (in-phase) component is responsive to buried metallic objects.
    The depth of penetration attained is dependent on a number of factors including the ground conductivity, the loop spacing and the orientation of the primary field (dipole orientation). A number of EM instruments are available which together provide a depth of investigation range of between 0.5m and 30m. The use of three or more loop spacings in both dipole orientations enables quantitative modelling of the depth to individual conductive layers. This is commonly known as EM depth sounding.
    Shown on the right is an EM31 Ground Conductivity Meter manufactured by Geonics Inc. of Canada. This instrument gives a maximum depth of investigation of approximately 6m in vertical dipole mode (dependent on ground conductivity). Data from the EM31 instrument is logged automatically using an on-board data logger and can be periodically downloaded to a field computer during the day for quality checking and initial data processing.
    RESULTS
    The results of EM profiling surveys are normally presented as colour-coded grids (as illustrated) or less often as contour plots. The computer fits an artificial surface to the data set by dividing the area into a series of 'cells'. The value of each cell is based on the values of the closest surrounding sampling points. Each cell is then assigned a colour based on its value.
    Shading of the data (as shown here) using an imaginary light source often helps enhance subtle anomalies within the data set.
    Buried conductors generally appear as complex anomalies due to their dependence on the relative orientation of the transmitter-receiver intercoil axis and the target. This governs the amplitude and direction of coupling of the conductor with the primary field. Linear conductors, such as pipes or faults, will normally appear as either a single linear high or a low flanked by two lower amplitude highs, depending on whether the intercoil axis is orientated parallel or perpendicular to the strike of the conductor respectively. Readings are normally negative over large sheet conductors (such as reinforced concrete) due to saturation of the instrument electronics.
    The image above represents the results of an EM31 electromagnetic profiling survey over the base of a lagoon. The NW-SE trending linear highs extending across the centre of the site represent a fault line. This intersects a number of circular anomalies (marked 3) which were interpreted as sink holes.
    Time Domain Electromagnetic Sounding (TDEM)
    OUTLINE
    This active method involves inducing eddy currents within subsurface conductors using pulsed electromagnetic (EM) energy transmitted from a square loop of wire located on the ground. The decaying secondary EM signal induced by these eddy currents is measured over a series of time windows immediately after the transmitted signal is shut-off using the transmitter loop, or more commonly, a smaller second receiver coil located at the centre or to the side of the transmitter loop. TDEM soundings are capable of providing information on the conductivity of different layers within the subsurface to depths of between 3-1000m.
    DETAIL
    This active method measures the bulk electrical resistivity of the ground by inducing eddy currents in subsurface conductors using pulsed electromagnetic energy transmitted from a square loop of wire laid on the ground. The decay of these induced currents results in a decaying secondary magnetic field which is measured over up to 30 time increments ('gates') immediately after termination of the transmitter pulse. Measurement of the secondary field can be made using either the transmitter loop or more commonly with a separate receiver coil located at the centre or to the side of the transmitter loop.
    In the case of horizontally layered materials the induced current loop will diffuse outwards and downwards with time whilst gradually decaying in amplitude. The speed of this diffusion and the amplitude of the secondary magnetic fields are related
    to the conductivity of individual subsurface layers. As a consequence thin resistive layers are generally invisible to TDEM soundings. Use is made of a very early time (capable of 1.2msec turn-off time) NanoTEM system with Zonge GDP-32 receiver owned by GSI (UK) Ltd. This system provides improved resolution of the near surface as compared with 'traditional' TDEM systems. The depth of investigation of a TDEM survey is dependent on the moment of the transmitted signal together with the conductivity of the subsurface layers. A larger moment (achieved through an increase in the loop size and/or transmitter current) and an increase in ground resistivity will result in increased signal penetration.
    Modelling of TDEM sounding data can be carried out using commercially available software programs as well as proprietary software. Background noise levels are commonly measured at each sounding location so that the quality of the data can be effectively monitored. Data falling below the measured noise level is discarded from the modelling process. A hand-held conductivity meter is used to log existing core from calibration boreholes and provide control for the modelling process.
    RESULTS
    Time-domain EM sounding results are generally presented as combined plots of the calculated apparent resistivity versus time and the modelled resistivity versus depth. The dotted lines in the second graph indicate equivalent resistivity models that also satisfy the observed data. Equivalence results from the inability to uniquely resolve the thickness and resistivity of a layer from its conductance value (thickness/resistivity). As long as the resistivity and thickness are changed within limits to give the same ratio there will be no appreciable variation in the apparent resistivity curve.
    Where a series of TDEM soundings are undertaken along a profile or series of profiles, 2D sections can be constructed by extrapolating the various layers indicated in the 1D models. If the data set is extensive then isopach maps of the depths to individual layers may also be produced.
    Time Domain Electromagnetic Profiling
    OUTLINE
    DETAIL
    Time domain electromagnetic profiling utilises a pulsed electromagnetic wave to induce secondary EM fields within subsurface conductors. The duration of these secondary fields, following shut off of the transmitter pulse, is dependent on the conductivity of the target, such that fields induced in metallic targets dissipate much slower than those resulting from ground conductivity. The secondary response is measured over a set time interval during the off period between pulses using one or more receiver coils. By measuring this response after dissipation of the ground component, the response from metallic targets is enhanced. TDEM profiling is consequently highly sensitivity to both ferrous and non-ferrous metals.
    The EM61 comprises a portable coincident loop time-domain transmitter and receiver together with an additional receiver loop. The latter enables depth-to-target estimations and discrimination between near surface and deeper target response.
    The EM61 uses a pulse frequency of 150Hz and a high powered transmitter providing a maximum depth of investigation of up to 5m (depending on target size). Output from the instrument is the integral of the time-gated secondary response, expressed in millivolts (mV).
    Commercial software exists for estimating depth to source using the raw data from the two receiver loops. When combined with the high sampling rate of the EM61, this enables rapid screening of a site for potential hazards such as unexploded ordnance (UXO) and buried drums.
    RESULTS
    The results of TDEM profiling surveys are normally presented as colour-coded grids (as illustrated at left) similar to other 2D profiling methods such as magnetics and horizontal loop EM. As a result of the large range in values encountered in a TDEM profiling survey (typically 2-2000mV) the colour-coded image is normally scaled logarithmically in order to provide detail at both ends of the data range.
    Very Low Frequency (VLF) Surveys
    OUTLINE
    Very-Low-Frequency (VLF) surveying is a continuous-wave (frequency domain) electromagnetic technique that uses low-frequency radio transmissions as the source. When these intersect a buried conductor they induce eddy currents that generate a secondary magnetic field concentric around the source of the currents. VLF surveys involve measuring the orientation of this field. As the instrument passes perpendicularly over a vertical target the vector orientation changes from a maximum on one side to a minimum on the other side. The method is primarily used in mineral exploration work but has also been successfully applied in engineering and groundwater surveys to detect conductive fault zones and other sub-vertical conductors.
    DETAIL
    Very Low Frequency (VLF) surveying is a continuous-wave (frequency domain) electromagnetic technique that utilises high power, low frequency radio transmissions as the source. Eleven major transmitters located across the globe generate these transmissions, providing a range of frequencies from 3kHz to 24kHz. Their primary use is in communication with submerged submarines and for long-range radio positioning.
    Sensed at a distance greater than a few tens of kilometres the EM transmissions act as plane waves propagating outwards horizontally. When these waves intersect a buried conductor they induce eddy currents that generate a secondary magnetic field concentric around the source of the currents. The strength of the eddy currents is greatest when the long axis of the conductor is oriented parallel to the direction of propagation (i.e. on a radial from the active transmitter). In this orientation the magnetic vector is acting tangentially. Modern VLF instruments enable measurements to be carried out at a number of different frequencies in sequence in order to ensure optimum secondary field signal strength. However, the orientation of the survey lines still has to be chosen to lie perpendicular to the expected orientation of the targets.
    VLF surveys involve measuring the orientation (tilt-angle/dip-angle) of the vector summation of the primary (horizontal) and secondary magnetic field vectors. As the instrument passes perpendicularly over a vertical target the vector orientation changes from a maximum on one side to a minimum on the other side. The point at which the reading changes from positive to negative is termed the 'cross-over' point and lies directly above the conductor. If the conductor dips then the anomaly shape will be distorted in either the positive or negative sense (depending on dip direction).
    The VLF method is primarily used in mineral exploration work but has also been successfully applied in engineering and groundwater surveys to detect conductive fault zones and other sub-vertical conductors.
    RESULTS
    The data acquired during modern VLF surveys normally comprises at least three separate parameters of the secondary magnetic field, including the amplitude of the field and its quadrature (imaginary) and in-phase (real) components relative to the horizontal primary field. Results are presented as profiles against distance as indicated below. Filtering of the real component or dip-angle measurement is often carried out in order to produce a maximum over the crossover point (the point lying directly over the anomaly), thus aiding interpretation.
    Advanced filtering of the real component of the secondary field can be used to produce a current density pseudosection as illustrated in the figure below. This provides an indication of current concentrations and their spatial distribution that approximately reflect the depth and location of sub-surface conductors.
      Where can I read more about designing Fixed Frequency Electromagnetic (EM) Profiling instruments?
      faycel, thanks for posting excellent piece of information.
        I found this at Geonics.com. Check out the other tech notes lots of good info on this site
        http://www.geonics.com/pdfs/technicalnotes/tn6.pdf
          Thanks Altra, I am grateful.
            If you are still looking for an appropriate computer program to base this design on, I have one. Your description in the Fixed Frequency Electromagnetic Profiling of what the program does, in particular the "into two orthogonal components, the real and imaginary (quadrature) components, representing respectively the vector components of the field in-phase and 90 degrees out of phase with the primary" etc is exactly the same as is done for an Inductively Balanced VLF computer based metal detector.
            My main interest is to get an open source design suitable for humanitarian demining that is better than anything currently available. I believe I have a fully working design that I'm currently documenting to make it easy for anyone to compile and implement. No electronic design required to get it up and running. I will be placing all the details on http://conzerned.org with the hope that this site can be used to develop the software further.
            Although the primary objective is humanitarian demining, other uses will be supported. Please report back here or on http://conzerned.org if you are still wanting this.
            Ken
              Ken
              ok humanise
              I am still wanting for this
              but http://conzerned.org cant be opened
