@6666,,,a 2nd attack isn't a good sign no so I wish her well and a fast recovery. Keep us posted. Thanks for the advice about the Crystal. @George,,,thanks for the info on jumper settings. Really looking forward to the coil experiments. Regards, Marty.
Hi 6666,
Yes that's the wind I used.
Sorry to hear about your wife best wishes to the both of you.
Thanks for the heads up on the crystal. Still waiting on boards and parts.
Found a interesting after market coil its a 8x13.5 DD jimmy sierra 50 khz old Whites gold max 3 coil.
Tx290uh 2.28 ohms
Rx 3.10mH
10.36 ohms. throwing it into the mix for testing as well.
As I wait for my Voodoo pcb to arrive, I decided to do a quick video on my YouTube channel on how to use a PicKit3 to load the Hex file onto the PIC. Obviously this is meant to guide people who may not be familiar with the process. https://youtu.be/O9V8fmQWXe4
Hi surfdetector,
Thanks for the video, I had ordered a tl866,2plus programmer and was kinda intimidated by the 54 pages of instructions. Your video summed it up where I could understand it better. It always helps to see something done.
Appreciate it.
I have this programmer and supported devices list is huge.
So far it hasnt failed on the chips i had to program. I can recommend it and its not complex to use at all.
Appreciate it.
Glad to hear the positive feedback. I agree with you, pictures and video go a long way in assisting the understanding process for new subjects. I also appreciate the many informative posts that you have made on the forum, they have helped me substantially.
Cheers
voila, the power section is done, I have adapted some voltage on the 100uf capa I lack one 25v to do. So I got a 16v after the 7805 ... it should work ... later on, after the aperitif
Hiya George,,,Can a LM555CN or a 7555IPAZ be used in lace of the NE555 please? If not, is an NE555P ok to use instead of NE555N? Also can a HEF40666 be used instead of 4066BP? Thanks, Marty.
Thank you George. I just have to calculate the wire length for the cable that needs to go from the pcb/enclosure, along the shaft and up the handle, before I build the LCD/Button section and also have to decide whether I'm using plugs for the cable or not. Thanks again, Marty.
Marty,
What sort of enclosure are you using for the LCD and the push buttons?
