Voodoo Main Discussion
    ID looks good on the bench, any plans to bury some targets and re test ?, congrats on getting it working.
    I will be doing a video of it at the beach on a regular hunt probably next week when I get my parts for the box and shaft. There should be plenty of iron to identify.
    • Originally posted by Mdtoday View Post
      When I clear the decks of current projects, I'll do a port and share.
      Thanks Mdtoday.
      I have just posted the full Mikroelectronika mikroC Pro project files in post #1 to assist you in the challenge.
      Looking forward to the result.
      Waltr - the configuration bit settings are part of the mikroC project files.
        Thanks Mdtoday.
        Thanks.I suspected they were.
        I XC I like having these in the code.
          Excellent, thank you for posting the project George, much appreciated.
          Cheers
          • Hi friends can you help i have pic18F452 can i use it .
            • Originally posted by sbalio1 View Post
              See post #526.
              • Hiya Alec,,What speaker are you using for your Voodoo? And did you have to change the value of R64? I only ask because Lamoiz mentioned problems with his project using an 8 ohm speaker. Thanks, Marty.
                • Originally posted by MartyJ1963 View Post
                  The external speaker that I have hooked up in the video is 154 ohm, it is from an old telephone hand set. The Headphones that I tested with it are 32 ohm and have built-in volume control. The volume is Extremely loud without a control. I installed the 33 ohm resistor and have had no issues with excessive heating.
                  • Thanks for the reply Alec,,I'll have to see what other speakers I can get hold of. Excellent work you did on the you tube videos!!,Regards, Marty.
                    • I am still with the problems of "noise" at the exit of the 2nd stage of the preamp .. and beep beep beep .. I checked and re-checked all the components ... I do not understand where it comes from ...
                        I kept the 8r speaker and installed a resistance of 180r instead of 33 ..
                          I would recommend using a high-impedance speaker (e.g. 50 ohms or higher).
                          Personally, I was using a set of headphones with a built-in volume control.
                          Although it doesn't show it in the circuit diagram, I sort of assumed (perhaps incorrectly) that constructors would also fit a volume control.
                          • Originally posted by lamoiz View Post
                            Did you miss post #536?
                            • Thanks everyone,,I only had 8 ohm x 1w speakers for my other projects so I just ordered 2 x Quinlon 0.5W / 16mm Diameter 50 ohm speakers for my Voodoos. Thanks again, Marty.
                                good evening george, I only had an 8r speaker on hand ..c is the reason for this choice .. yes I had not read the post 536, I will make you a picture of that tomorrow. thank you for everything.
