Voodoo Main Discussion
    So we need to change wording on page 29 and add to post #1, good to see these things being found.
    It's very difficult to get technical documentation 100% correct. I was reading an Arduino book recently, and discovered several errors. The book was published by a reputable publishing company, and their experienced proof readers still managed to miss stuff.
    • Hi George, the iron chatter you mention a couple of times in the book may be mostly eliminated using a '3rd channel' in software as "Disc minus Phase" here this should be Disc - PI channel then triple AND the 3 channels for the final output..
      Ive used it successfully on a couple of projects it works well for the mismatched channel overlaps at crossovers.. usually big iron!
      Hang on theres another bit of logic to go with that 3rd channel.. let me just check back..
      • Hi everyone . I was away yesterday, I had a car accident problem .... a girl and her cell phone smashed my car at a crossroads ... put my car in the trash .. *****.
        Otherwise here are some pictures of the oscilo ..
ID:	358662tp5 tp2Click image for larger version
        a lot of noise on tp3 ..pff I don't know why ..
        • Ok its when both channels go high.. then
          before sending audio output start timing the signal..
          If its short duration and either channel are higher than
          a small signal level then ch.3 'Disc minus Phase' must be high
          If so then send detector audio output..
          Here 'ch3' may be 'PI minus disc' as its the disc channel that has the phase element
          Hi Lamoiz i hope youre OK.. im starting Voodoo construction tonight
          ill see what i get on tp3..
          • thank you Math, it's okay ..
            George, I still have the beeps beeps beeps all the time .. do you have any idea where this could be?
            • I am complete on the Bench
              I have completed my build on the bench. I need to wait for some parts and then I shall box up the project and take it out for a spin. I shall post a short video tomorrow on my YouTube channel of the project operating in Hybrid mode. I have attached a picture from the Disc pre-amp output which appears somewhat different than in the book. I am getting about 8" on a George VI penny and about 5" on a US nickle. More tweaking is needed, currently I have all settings in default and I am using a F75 coil.
              • Originally posted by surfdetector View Post
                [ATTACH]53849[/ATTACH]
                hi surf,
                me too I finished a long time ago, but I still have the beeps .. and I can not find the problem .. me the test was done with the tesoro .. and my other home coil works too.
                • Originally posted by lamoiz View Post
                  hi surf,
                  Do you get the beeps in both hybrid and PI mode? I wonder if you are getting EMI that could be causing it?
                    I have the beeps in pulse mode, very little in hybrid mode.
                    I tried outside, it's the same problem, I don't understand,
                    what do you think of the tp3 measure? there is a lot of osciliation after the impultion .. no ??
                    • hi friends i have pic18f452 can i use it for this machine
                        What does your coil flyback look like?
                          [ATTACH]53841[/ATTACH]tp3 tp2
                          [ATTACH]53842[/ATTACH]tp5 tp2[ATTACH]53843[/ATTACH]tp6 tp3
                          [ATTACH]53844[/ATTACH]tp9 tp2
                          [ATTACH]53845[/ATTACH]tp10 tp3
                          Sorry to hear about the car accident. Hopefully no-one was injured.
                          Firstly - switch your scope channels from AC coupling to DC.
                          Secondly - do you have your scope probes set to x10? The amplitudes of the signals are both about 10 times smaller than expected.
                          Please change the settings and re-post the images.
                          • Originally posted by Math View Post
                            When I was discussing chatter in the book, I was referring to some of the experimental prototype versions. At one point (page 10) I state: "Eventually after much effort, the noise, instability, chatter, and timing issues were all resolved."
                              Well done. That looks good.
                              The extra ringing is occurring during the TX-on time, and does not affect correct operation of the detector. Fig. 2-1 shows the result for a Troy coil, so the Fisher F75 coil may quite possibly be different.
                              • Originally posted by sbalio1 View Post
                                Not without modifying the source code to handle the differences and then re-compiling to generate a new hex file.
                                http://ww1.microchip.com/downloads/e...doc/39647a.pdf
