Voodoo Main Discussion
    There is a comparison test on Yotube. 3.5 allegedly works faster.
    I will order model 3. Seems like optimal one for my needs.
    Yes, it must be. I made two voodoo's and i have exactly the same behavior on both.
    I located one White's Spectra V3 coil and will obtain it for testing.
    Other coils that i have are not suitable.
    I just tested my whites V3i concentric coil and it may be suitable, but does anybody know where you can buy a whites 5 pin coil socket ? and what type they are ? thanks
    • Originally posted by lamoiz View Post
      temperature of my workshop 20 .. and measurement of u6 after 5 min of use 24.5 .. measurement with a pt100 on contact.
      Thank you thats good information, I am just a bit surprised at how warm the reg is already, the voltage is ok.
        I just tested my whites V3i concentric coil and it may be suitable, but does anybody know where you can buy a whites 5 pin coil socket ? and what type are ? thanks
        I think that they use one of these:
        https://www.switchcraft.com/products...spx?Parent=599
          The PICKit 4 is quite expensive, so I would get the PICKit 3.
          Don't know what 3.5 is. Never heard of it.
          It sounds like it's an issue with the PIC18F45K22. Most likely a configuration problem.
          I was intending to load and fire up 2 boards with the different processors to work through the C code port from 18F4520 to 18F45K22, which would have helped sort the config problem but both my orders for parts and PCBs that I was hoping to receive before Christmas are delayed.
          Element14 has just informed me of a 2 week delay in 1 resistor value, I marked the order to send all parts in 1 shipment, so nothing to load the boards with, which is neither here or there because the JLPCB oders is also delayed with DHL.
          It has been sitting in Hong Kong since 14th Dec.
          That time of year.
          I just noticed, I could get a PIC18F45K22 locally , so maybe I'll grab one and fire it up on a breadboard with the power supply, as I can rig that up easy enough and it will help figure out what is required in Configuration at least.
          Cheers
          Mdtoday
          • Originally posted by Mdtoday View Post
            That time of year.
            Cheers
            Mdtoday
            Not a good time of year to order stuff online, especially from China.
            I ordered some PCBs from JLCPCB on the 4th December and received them in a couple of weeks. It was surprising that they got here (UK) so quickly, especially since they came via Germany. I was a bit concerned that they may get delayed at the ports due to the upcoming Brexit problems. Maybe it was because I had them delivered via DHL Euro Express.
            • Ok, this is interesting!
              Since i am restless to see this alive and this is loooong weekend; i decided to give it a try again.
              This time i made simple JDM programmer (state of the art among my works, see the photos).
              I have Dell Optiplex 7010 among other computers. I7, 4th generation, 16GB RAM, 120GB SSD, 1TB WD...
              Overall pretty usable machine.
              But i never really look it's back side, so i didn't know that it has old com port (RS232) !???
              That gave me motivation for this.
              The other day i spitted hard on PICPgm Programmer software, since it didn't recognize my old parallel port "burner".
              So i made JDM, use several wires to connect it with "Ready for PIC" board, just to use it's DIL socket.
              And gave it a try. Total SUCCESS!
              Now PICPgm Programmer recognizes programmer and chips flawlessly!
              Small notice: i only had to lower the speed (Time Delay Factor) in options, from fast to almost slowest.
              So i flashed both 18F4520 that i have.
              Than i placed them in dil sockets on two Voodoo pcbs.
              Than i performed series of basic tests. All voltages are correct.
              LCD is now working. Buttons all working.
              Sound is ok.
              All the signals from PIC are ok.
              With scope i see pretty decent flyback.
              But!
              Detection... ZERO!
              So i looked around and i founded out that offset voltage at NE5532 is -1.4v !!!
              And with turning the trimmer to adjust it; it is not changing at all!??
              I scoped from coil across the two diodes at the input; yes i see the PI RX signal alright.
              So i suspected both NE5532. Fortunately i have 4 of those more.
              Not from the same series and same age, those 4 i stripped down from some audio mixer, 100% originals, 100% accurate and high quality.
              So i replaced NE5532... same thing. Can't adjust offset. At both pcbs the same behavior.
              So right now i am stuck there. Just took short rest to post this post and inform you about the news.
              • Originally posted by surfdetector View Post
                Thanks , they are rare around here.
                • Ok i solved it.
                  It also may be possible weak point of the design, not sure yet.
                  All the time it was up to 78L05.
                  I tried 3 brand new pieces and all behave the same.
                  Chokes and wont provide +5V. Only at short moments.
                  Trick was that when in Menu; damn thing provides +5v.
                  In operating mode not.
                  At PW 150uS overall power consumption is 150mA.
                  At PW 100uS overall power consumption is 122mA.
                  So i solved it very simple; instead 78L05 i put 7805.
                  And everything works just fine.
                  I am satisfied with air "depths" i get with small ~18cm coil.
                  I will work around it something else, but right now i can't test Disc mode, until Spectra V3 coil arrives.
                  Need to test this on longer working period to see if anything gets hot and ready for magic smoke!
                  • 10 minutes of constant working in Pulse mode.
                    Nothing gets hot, no magic smoke.
                    Haven't tried with PW wider than 150uS.
                    Took one home made coil for IB.
                    0.7mH and 12mH.
                    Skim testing, approx tuning cap (most probably wrong).
                    Not discriminating by now.
                    I'll have to read again the book and search for how to properly adjust R22.
                    Also how to properly trim the tuning cap.
                    What i am missing here is Sensitivity adjustment. In both modes.
                    Without it it will be pretty much useless on real soil.
                    Also it would be nice if it had some kind of visual indication in Pulse mode.
                    Somehow LCD looks stupid indicating nothing in Pulse mode.
                    But that's the part probably very easy to add in code.
                    That's all for this night. I am tired.
                    Damn 78L05 killed me!
                    Good job Q. but not finished, i had to tell you this.
                    Add Sensitivity in both modes. That's important.
                    I don't understand Treshold function here.
                    I can't easy see the difference.. actually can't see it at all.
                    Too tired to search in code.
                    PIC code is pretty much gibberish for me, must take time to learn it.
                    • Ah yes, more remarks i have (will forget until tomorrow).
                      Pulse mode in motion?
                      Not serious PI like that. Probably automatic/adjustable SAT will do.
                      Also audio amplitude should change along with signal changes.
                      Volume option is missing. Important!
                      Too "binary" audio. Don't like it.
                      Maybe if i toss the NE555...?
                      Yet still will be "binary".
                      Because you did it like simple switching.
                      That's all by now. These days i will most probably figure out more remarks!
                      I tried 7660 and it gets hot in several seconds.
                      LT1054 stays cool.
                      Q. you opened Pandora's box with this! (or can with worms, pick what you like more)
                      You will not have peace from this, next several months, i tell ya!
                        Not sure what visual indication would be useful in pulse mode.
                        Threshold setting is in the menus, but (as I said in the Conclusion) the menus are an area for improvement.
                        Personally, I think the threshold should be a separate external control. Knobs are easier to twiddle than using a menu system.
                          There is obviously a lot of improvement that could be done on this design, but the basic concept works. As you play around with it and make changes you will understand why certain things were done the way they were.
                            The PICKit 3.5 is a pirate clone.
                              See post #389
                                Progress bar indication, the "scale". As signal appears and increases; progress bar also to rises.
                                Is better anything than nothing.
                                Also power consumption on the LCD would be nice thing.
                                But it probably will need additional changes in hardware. Not too complicated i assume.
                                Honestly i can't tell the difference between various Treshold adjustments.
                                Potentiometer will do. But also up/down (or +/-) buttons can serve to adjust Sensitivity in working mode.
                                Motion type PI detector with such binary response is not most happy solution.
                                Either to make it non motion, either to smooth up the audio response.
                                Yes i think i understand the whole concept and why is done this way.
                                It is more like educational example. Many things to learn in process of making it.
                                But considering how huge and respectable effort you put in it... it would be shame to leave it as it is now.
                                Because is obvious it has lot of potentials and can be turned easy to very serious machine.
