Voodoo Main Discussion
You can remove the 1k resistor.. just a leftover from a previous drawing. It works without an offset because it get filtered out later on but good idea to add one. The other two, I Donno but will check my original board.
also, playing around, its best to keep the sample width a little smaller. I changed R47 from 22k to 15k.
Originally posted by dfbowers View PostYou can remove the 1k resistor.. just a leftover from a previous drawing. It works without an offset because it get filtered out later on but good idea to add one. The other two, I Donno but will check my original board.
