I have recently opened up a coil of mine because it was falsing even with the slightest touch, no matter what setting (I can't afford to send it back and forth, postage would cost almost as much a new coil!). Upon opening it up, I see that there's a wire sticking out from the middle, I moved it around and that's not the source of the problem. I tap the sponge and it falses then, or even if I tap other parts of the coil.
Does anyone know what could be causing this problem, and what the solution might be?
Here's a photo of coil opened up:
