Hi Davor, Thanks for a very informative reply.
So the DDO configuration requires a dedicated receiver.
So for a given detector with certain coil specs can be built if the coil parameters are used according to your example and Aziz's Top hat example plus calculations for all coils presented here?
And when you say business as usual, Is faraday shielding still important or can it be eliminated if coils are set and tuned correctly in a true anti phase state??
I like this coil configuration as the coils are practically on a horizontal plane if constructed, which could ease in building of such a coil. As you say though not a true reverse phase configuration yet, according to Aziz's sims and observations so far.
Correct, using of figure 8 coils is a compromise and depth is decreased.Ground suppression as you say is not taken care of with such coil, therefore you still require some form of Ground balancing circuitry.
Will be easier to test these coil parameters given on a basic PI such as the Surfpi with two coil configuration, having TX and separate RX.
Cheers Sid
Originally posted by Davor
View Post
View Post
View Post
View Post
Cheers Sid
