Advanced PI coils
    Tinkerer,
    Sounds like you're talking about a coplanar concentric coaxial coil. I don't think you can get very effective EMI cancelation and still get good sensitivity. I was addressing the stacked concentric coaxial coil, which is what Aziz is talking about. In that case, best EMI rejection is when both RX coils are tightly spaced (which would then be coplanar); as you spread the coils apart sensitivity will increase up to some point, then begin to decrease as it forces the target farther away from the TX coil. The optimum point can be calculated mathematically (Aziz, are up to the challenge?) or it can be determined empirically.
    Oh noooo!, I hate math!
    Well, I'm doing some variations of distances. 2 inch, 5 inch, 10 inch (distance of RX+ and RX-, TX in the middle). One can probably see the location of the optimal point. If required, I can do more distance variations of course.
    Yep, that's the crucial point. The more the distance, the more the EMI rejection is screwed up and the less the target response is cancelled. And the TX being farther away from the ground too.
    I'll try to look for the optimal point.
    Aziz
    • Regarding the optimum distance of RX+ and RX- in a co-axial stacked AI IB coil.
      I have made it for 2 inch, 5 inch, 7.1 inch, 10 inch and 15 inch co-axial distances. There isn't an ultimate optimum distance. And the answer is complicated.
      For detection distances 0" - 10", the 5 inch co-axial distance rules.
      For detection distances 10" - 20", the 7.1 inch co-axial distance rules.
      For detection distances above 30", the 10 inch co-axial distance rules.
      The 2 inch version isn't going deep.
      For a specific detection distance, there exist an optimum co-axial distance. But this optimum point changes with detection distance. We have to make a compromise.
      A good compromise would be somewhere between 5 inch and 10 inch. That's the half diameter unit to full diameter unit co-axial distance. I personally tend to use half diameter unit or slightly more.
      Now looking forward to see which coil is going to make the running (including the tophat-coil, concentric co-planar coil, etc. ).
      Cheers,
      Aziz
      • Hi guys!
        I would like to make a good coil for my Surf PI machine. I've made one out of enameled copper wire but it seems to have too high capacitance, because the speaker beeps when I touch the coil. The ground is not detected, but wet grass and snow make this beep. The coil has no shield.
        How about using UTP cable? How to connect its wires together? Does anyone have a good documentation of making one?
        Or should I use PVC or teflon coated copper wire wound simply?
        Which one would be better?
        Thank you for your answers.
        • Originally posted by andva View Post
          Hi guys!
          could affect: http://www.metdet.ru/korsina2.htm
          I've tested this with more Surfmaster PI
          feels a € 1 coin to 28cm
          • Hi guys,
            I'm getting more and more surprised about the calculated results. Normalizing the coil configurations to an equivalent RX EMI noise induction ( N(RX)*A(RX) = const) reveals where the real magic is.
            I'm not finished yet. Stay tuned..
            Estimated publishing date: The day before the end of days (tomorrow).
            Cheers,
            Aziz
              Hi guys,
              Cheers,
              Aziz
              I will wait for your results before building my new coil.
                Me too Tinkerer.
                The results are very very interesting so far.
                Did you know, that the standard concentric co-planar (CC) IB coil (RX, BX: 0.5 times diameter of TX) performs almost equally regards to signal-to-noise (SNR) criteria (EMI noise induction)?
                And I can see the comparision to an equivalent DD coil. It does not perform better than CC IB coil.
                Mono coil at depth (30"): 1.00 (reference)
                CC at depth: 0.96 times of the mono coil response
                DD at depth: 0.62 times of the mono coil response
                You will be very surprised about the anti-interference (AI) coils, when there is more room for cranking up the gain to compensate the losses and can finally get into the magic beneficial region.
                Cheers,
                Aziz
                  Me too Tinkerer.
                  Cheers,
                  Aziz
                  Thanks for the update.
                  Your comparison numbers between CC and mono confirm my own measurements.
                    Another update:
                    Can the mono coil be outperformed (regards to SNR)?
                    The answer is: Yes!
                    I have to make more coil simulations as a consequence of this finding.
                    Cheers,
                    Aziz
                    • So we learn it tomorrow? I was just about to go and buy some twisted pair wire for my stealth coil-in-a-bag anti interference, and good for roaming the beaches brand new coil based on a Davor-Sergey concept. We'll see what's on a menu tomorrow
                      • Hi all,
                        I'm almost finished with the most common and interesting coil types. The question is, whether I should take the loser figure-8 coil into account. But this figure-8 coil is causing a lot of work for nothing.
                        I have analysed the following 10 inch coils so far:
                        - Mono coil (reference)
                        - Mono + stacked AI coil (The Eric Foster's coil in this thread - see the coil picture in the earlier post)
                        - Ground loop (GL) coil (TX, RX separate, RX smaller)
                        - Ground loop (GL) + stacked AI coil
                        - Co-axial stacked AI IB coil
                        - Concentric co-planar IB coil
                        - Tophat AI IB coil
                        - DD IB coil
                        AI is referring to the anti-interference (AI) feature (RX+, RX- connected anti-phase in series).
                        IB is referring to the induction balance (IB) feature.
                        If IB is not mentioned, it's a plain pulse induction (PI) coil.
                        Well, I'm thinking of adding a few configurations as well (Davor-Sergey at least. BTW!, I have found a configuration, which doesn't require a compensation (CX) coil).
                        BTW, I can also answer the following question regarding the concentric co-planar IB coil:
                        What is better: Smaller RX/BX or larger RX/BX in regards to SNR?
                        One interesting thing could be measured however:
                        The AI EMI rejection ratio for different co-axial distances. So we know the gain margin for compensation of the target response losses (the break-even point) and the remaining gain to get into the beneficial region.
                        I think, I'll make new measurements with an ultra low-noise amplifier to figure out the rejection ratios.
                        Oh yes, a lot of calculated data needs to be imported into an excel table, which is also causing a lot of work.
                        Be patient please.
                        Well, I have almost two days before the doomsday! I should really hurry up now!
                        Cheers,
                        Aziz
                        • stupid question, removed
                          • Aziz, back in 2002 I was interested in the ratio of TX to RX diameters to minimise the signal from surface ground viscosity response in CC coil. The computed result was between 0.7 and 0.8. Can you factor in that requirement and what is the trade off?
                            Eric.
                            • Originally posted by ppodg View Post
                              Aziz, are you able to calculate the optimum position of tx between both rx coils (concentric, coplanar)? Does it make sense?
                              In case you mean the IB coil, yes. It is mandatory to compare the IB coil in an induction balanced coil condition. All IB coils are in induction balance state.
                              In case you mean the co-axial stacked AI IB coil (RX+, TX, RX-), the TX position is simply the mean co-axial distance of RX+ and RX-. Not required to calculate the optimum TX IB position.
                              In case I haven't answered your question, please specify it more precise.
                              Aziz
                                Eric.
                                Eric, do you referring to the concentric co-planar IB coil or
                                the large TX, small separate RX PI coil (the ground loop coil principle)?
                                Please specify your question(s) more precise.
                                Aziz,
                                confused
