Advanced PI coils
  • Originally posted by PATCHES JUNIOR View Post
    Seems like all your great ideas are getting shot down. Especially your bad language. Can you not go a month without the filth?
    PJ, do you have a good idea?
    Oh yes, I forgot: You don't do anything for free...
    How about 100 shares of "MadLabs Inc."(c)(r)(tm)?
    *LOL*
      The original setup with Cx was fine. Without Cx a bit more interesting. Don't count it as failure, you just found a way not to do it
      BTW, seeing PJ poisoning the well, you just know you are on the right track. A real ground balancing coil would surely make some more advanced rigs a bit less palatable considering their notoriously unpalatable price tags.
      I'll try a bit more. The variation with a compensation coil compared to the others would be interesting however. And how it compares to the figure-8 types. You know, the figure-8 types lose a lot of depth too.
      But I like equivalent RX+ and RX- coils (equivalent electrical characteristics). You will get much more with it.
        Going back to the Eric Foster type coaxial stacked coil which I used in the early 1980's in my PPD1 detector, there is another way of operating it. The centre coil is the TX, but is also RX1 so that it operates as a standard mono. This is fed to its own RX channel, sampled, differentially integrated and amplified such as to give an "all metal" signal. In the PPD1 this gave an audio only signal. RX2 and RX3 were similar size RX coils held in electronic balance. This fed a discriminator channel, sampled and integrated in the same way but displayed on a centre zero meter. The signal sample however was 4uS after TX switch ON. The differential earth's field sample was shared with the "all metal" channel. For non-ferrous metal the meter swung right and for ferrous it swung left. In air, this discrimination was very reliable, even steel washers and bottle caps showed as ferrous. This detector was primarily for beach searching and had no ground balance, hence inland it had limited use.
        I used a Garrett 7in diameter stacked coil former as used in one of their VLF detectors at the time. The TX/RX1 acted as a standard 7in mono, and the RX2, RX3 balance coils were just for discrimination, but I was able to get almost the same detection range from the disc channel as the mono channel even though the spacing of RX2 and RX3 was only about 1.5in. The "all metal" channel had a comparator that switched on the disc. meter circuit when a few mV had been exceeded, so that noise did not appear on the meter in no signal conditions.
        I will find the schematic of the disc channel and auto balance circuit in due course and post it on the Forum, unless it is there already - have to check.
        Just another way of using the EF stacked coil, and with a good GB arrangement would have lots of potential. It would be interesting to try, say, 10in TX/RX1 with 7in RX2, RX3 for a nice coil shape that thins out toward the edge.
        Eric.
        Sure Eric. I can make a comparsion of whatever you prefer. But I'm trying to understand the coil you are describing. Maybe a better description of the coil or a sketch would help alot.
        I'll describe the coil configuration what I've understood:
        10in TX = RX1 (mono) placed in the middle of RX2 (near ground) and RX3 (above TX)
        RX2, RX3 = 7in (anti-interference)
        All coils co-axial arranged.
        The co-axial distance (between RX2 and RX3): how many inches?
        Did I understand it right?
        If not, please give me more input data.
        Cheers,
        • Hi Davor,
          regarding the Davor-Sergey-Ppodg IB AI coil (the magnetic field strength cross-section coil configuration shown here earlier, named as "Davor-Sergey-Ppodg-CC-AI-Coil-01.jpg"):
          Very poor performer (compared to the equivalent 10 inch mono coil).
          At depth (30 inch): 100 (!) times lesser response compared to an equivalent mono coil
          I made the 10 inch TX, 0.8 RX1, 0.4 RX2, 0.4 CX (4 mm apart from RX2) version:
          At depth (30 inch): 50 (!) times lesser response compared to an equivalent mono coil
          Compared to the co-axial offsetted larger RX coil version (without the CX coil), a definitely loser coil. The one I've shown without the CX coil is much better and easier to build.
          At depth (30 inch, 0.71 version): 11.3 times lesser response compared to an equivalent mono coil
          At depth (30 inch, 0.5 version, slightly thicker): 8.4 times
          It doesn't really make sense to follow the CX versions IMHO. We have to wait for PJ making us a break-through proposal.
          Cheers,
            Very poor performer
            Yes, moments mR+ and mR- very close
            I did here such coil => http://www.md4u.ru/download/file.php?id=5970
            • More Coil Analysis To Go
              Hi all,
              we aren't finished at all. There are more coil architectures to analyse and compare. Particularly the ones, which don't have a linear hot spot region/axis.
              Particularly:
              - Omega IB coil (this one is very interesting to compare)
              - Figure-8 (different configuration)
              - Tandem coils
              It seems, I have to code my coil software to find the maximum response region. But this is an investment, which is very worth to do.
              • Upgrading Coil Software finished.
                Hi all,
                I've just finished coding the coil software to make me less work. I should have done this a long time ago .. anyway.
                We can continue the comparison with the complex max. sensitivity region. I could provide the max. sensitivity for the reference mono coil regards to its edge region too (pin-pointing and max. near sensitivity region). A fair comparison of pin-pointing feature is possible now.
                Omega (IB) coil... you are the next candidate in my list..
                Cheers,
                • Omega (IB) coil... you are the next candidate in my list..
                  In case you need the coil info.
                  • I will be interested to see if Aziz's simulations confer with my testing of these coils for PI work I must add I was not suitably impressed to go any further.
                    Regards, Ian.
                    • Hi IBgold
                      so you found the Omega (IB) coil no good for PI.
                      Do you think that the ratio's of the coils are wrong for PI ?
                      It will be interesting to see Aziz's results.
                      • Thanks 6666,
                        I'll try different diameter ratios. Could take a bit as the calculations need much more time this time.
                        Cheers,
                        Aziz,
                        curious too
                          • Preliminary Omega Coil Comparison Result
                            This is the Omega IB coil vs. mono coil. Hey, it's performing better than DD-IB coil.
                            BX/BU: Bucking coil 0.4 times TX diameter
                            RX: Receive coil 0.5 times TX diameter
                            Interestingly, the hot spot axis remains almost at the center axis (approx. -1 cm +/- 5mm from the center position of the TX).
                            Ok, I've added DD-IB, CC-IB (0.5RX) to the comparision too.
                            Coil Comparison (Calculated Response Ratio to Reference Coil)
                            © 2012 by Aziz Ögüt. All Rights Reserved. 20-Dec-2012
                            Reference Coil: 300 µH Round Mono Loop Coil
                            10" Double-D Induction Balanced Round Coil 10" Concentric Co-planar Induction Balanced Round Coil (0.5) 10" Omega-IB (0.4BX, 0.5RX)
                            Target Depth [inch] Target Depth [cm] Relation to Reference Relation to Reference Relation to Reference
                            1 2,5 2,188 3,510 6,494
                            2 5,1 0,973 3,245 2,914
                            3 7,6 0,771 2,631 1,936
                            4 10,2 0,703 2,126 1,511
                            5 12,7 0,673 1,786 1,275
                            6 15,2 0,657 1,563 1,131
                            7 17,8 0,647 1,414 1,038
                            8 20,3 0,641 1,310 0,975
                            9 22,9 0,636 1,236 0,931
                            10 25,4 0,633 1,182 0,899
                            11 27,9 0,631 1,140 0,875
                            12 30,5 0,629 1,108 0,857
                            13 33,0 0,628 1,083 0,843
                            14 35,6 0,627 1,063 0,831
                            15 38,1 0,626 1,047 0,822
                            16 40,6 0,625 1,033 0,815
                            17 43,2 0,625 1,022 0,809
                            18 45,7 0,624 1,012 0,804
                            19 48,3 0,624 1,004 0,800
                            20 50,8 0,624 0,997 0,796
                            21 53,3 0,623 0,991 0,793
                            22 55,9 0,623 0,985 0,791
                            23 58,4 0,623 0,981 0,789
                            24 61,0 0,623 0,977 0,787
                            25 63,5 0,622 0,973 0,785
                            26 66,0 0,622 0,970 0,784
                            27 68,6 0,622 0,967 0,782
                            28 71,1 0,622 0,964 0,781
                            29 73,7 0,622 0,962 0,780
                            30 76,2 0,622 0,960 0,779
                            Now let's look, whether we can get a better Omega coil.
                            Cheers,
                            • Omega IB Coils vs. Mono Coil
                              This is a comparison between different diameter ratios of BX (small inner part of TX, kind of bucking coil) and RX of an Omega IB Coil vs. a mono coil. The 0.33 diameter variant (0.33BX, 0.33RX) perform a bit better (less noise, better SNR, better pin-pointing).
                              Indeed, not that bad for it's simplicity compared to a DD IB coil.
                              10" Omega-IB (0.4BX, 0.5RX) 10" Omega-IB (0.4BX, 0.33RX) 10" Omega-IB (0.5BX, 0.5RX) 10" Omega-IB (0.33BX, 0.33RX)
                              Target Depth [inch] Target Depth [cm] Relation to Reference Relation to Reference Relation to Reference Relation to Reference
                              1 2,5 6,494 14,723 6,822 14,584
                              2 5,1 2,914 5,361 2,905 5,513
                              3 7,6 1,936 3,003 1,841 3,110
                              4 10,2 1,511 2,058 1,398 2,139
                              5 12,7 1,275 1,594 1,165 1,661
                              6 15,2 1,131 1,337 1,026 1,397
                              7 17,8 1,038 1,181 0,937 1,237
                              8 20,3 0,975 1,080 0,876 1,134
                              9 22,9 0,931 1,011 0,834 1,063
                              10 25,4 0,899 0,962 0,804 1,014
                              11 27,9 0,875 0,926 0,781 0,977
                              12 30,5 0,857 0,899 0,763 0,950
                              13 33,0 0,843 0,878 0,750 0,929
                              14 35,6 0,831 0,861 0,739 0,912
                              15 38,1 0,822 0,848 0,730 0,899
                              16 40,6 0,815 0,837 0,723 0,888
                              17 43,2 0,809 0,828 0,717 0,880
                              18 45,7 0,804 0,821 0,712 0,872
                              19 48,3 0,800 0,815 0,708 0,866
                              20 50,8 0,796 0,810 0,705 0,861
                              21 53,3 0,793 0,805 0,702 0,857
                              22 55,9 0,791 0,801 0,699 0,853
                              23 58,4 0,789 0,798 0,697 0,850
                              24 61,0 0,787 0,795 0,695 0,847
                              25 63,5 0,785 0,793 0,694 0,844
                              26 66,0 0,784 0,790 0,692 0,842
                              27 68,6 0,782 0,789 0,691 0,840
                              28 71,1 0,781 0,787 0,690 0,839
                              29 73,7 0,780 0,785 0,689 0,837
                              30 76,2 0,779 0,784 0,688 0,836
                              Notice: The comma should be a decimal dot of course. This is due to internationalisation.
                              Next: Let's compare the CC-IB-AI coil against the Tophat IB AI coil. The CC-IB-AI contains another RX- coil co-axial above the coil arrangement of the standard CC-IB coil.
                              Cheers,
                              • CC IB AI Coil vs. Tophat IB AI Coil vs. Mono Coil
                                This is the concentric co-planar IB AI coil (CC IB AI) comparison against the other ones. The CC IB AI coil has additional a RX- coil, placed co-axial above the standard concentric co-planar IB coil to get the AI feature.
                                Which is going to make the running?
                                CC IB AI or Tophat IB AI coil?
                                See yourself below.
                                (I hope, the wide excel table fits into the forum page.)
                                10" Tophat 0.5 CC IB AI Coil (5 inch distance) 10" Tophat 0.5 CC IB AI Coil (10 inch distance) 10" Tophat 0.33 CC IB AI Coil (5 inch distance) 10" Tophat 0.33 CC IB AI Coil (10 inch distance) 10" CC IB AI (0.5, 5 inch co-axial distance) 10" CC IB AI (0.5, 10 inch co-axial distance) 10" CC IB AI (0.33, 5 inch co-axial distance) 10" CC IB AI (0.33, 10 inch co-axial distance)
                                Target Depth [inch] Target Depth [cm] Relation to Reference Relation to Reference Relation to Reference Relation to Reference Relation to Reference Relation to Reference Relation to Reference Relation to Reference
                                1 2,5 6,412 6,636 17,376 17,663 4,100 3,703 12,702 11,401
                                2 5,1 4,374 4,581 8,267 8,537 3,314 3,231 7,198 7,101
                                3 7,6 2,978 3,176 4,468 4,714 2,479 2,537 4,143 4,274
                                4 10,2 2,169 2,364 2,849 3,081 1,897 2,013 2,711 2,892
                                5 12,7 1,696 1,891 2,057 2,281 1,523 1,666 1,981 2,177
                                6 15,2 1,401 1,598 1,616 1,838 1,278 1,436 1,567 1,769
                                7 17,8 1,205 1,406 1,343 1,566 1,109 1,278 1,307 1,515
                                8 20,3 1,066 1,271 1,161 1,385 0,987 1,164 1,132 1,344
                                9 22,9 0,962 1,172 1,030 1,256 0,894 1,079 1,006 1,222
                                10 25,4 0,882 1,095 0,932 1,160 0,822 1,012 0,911 1,130
                                11 27,9 0,818 1,034 0,855 1,085 0,763 0,957 0,837 1,058
                                12 30,5 0,765 0,984 0,793 1,025 0,714 0,912 0,776 1,000
                                13 33,0 0,720 0,942 0,742 0,974 0,672 0,873 0,726 0,951
                                14 35,6 0,681 0,905 0,698 0,932 0,636 0,839 0,684 0,909
                                15 38,1 0,647 0,872 0,660 0,894 0,605 0,809 0,647 0,873
                                16 40,6 0,617 0,843 0,627 0,862 0,577 0,782 0,614 0,841
                                17 43,2 0,591 0,817 0,598 0,832 0,552 0,758 0,586 0,812
                                18 45,7 0,567 0,793 0,572 0,805 0,529 0,735 0,560 0,786
                                19 48,3 0,545 0,771 0,549 0,781 0,508 0,714 0,537 0,762
                                20 50,8 0,525 0,751 0,527 0,759 0,489 0,695 0,516 0,740
                                21 53,3 0,506 0,731 0,508 0,738 0,472 0,677 0,497 0,720
                                22 55,9 0,489 0,714 0,490 0,719 0,456 0,660 0,479 0,701
                                23 58,4 0,473 0,697 0,473 0,701 0,441 0,644 0,463 0,683
                                24 61,0 0,458 0,681 0,458 0,684 0,427 0,629 0,448 0,666
                                25 63,5 0,445 0,666 0,443 0,667 0,414 0,615 0,434 0,651
                                26 66,0 0,432 0,651 0,430 0,652 0,402 0,601 0,421 0,636
                                27 68,6 0,420 0,638 0,417 0,638 0,391 0,588 0,408 0,622
                                28 71,1 0,408 0,625 0,406 0,624 0,380 0,576 0,397 0,608
                                29 73,7 0,397 0,612 0,395 0,611 0,370 0,564 0,386 0,595
                                30 76,2 0,387 0,600 0,384 0,599 0,360 0,553 0,376 0,583
                                The Tophat(c)(r)(tm)(free) coil is "World's best IB AI coil design"(c)(r)(tm)(free). Probably until someone comes with a break-through coil idea.
                                Cheers,
