What's everyone using on their homebrew coils to attach it to the rod? Don't want to use metal but figure there might be something starting me in the face
Yeah the ears on the coil itself. I'm all over the nylon bolt!
Thanks all
Without a shell which have the ears built in, your options get more limited. Davor came up with a neat trick on his IGSL with a mop handle I believe. Only other option I can think of off hand would be to fashion your ears from 1/4 inch thick (6mm) plastic or plywood paneling and epoxy that to your base.
I made wood forms and vacuum formed plastic over them for coil shells. These have the ears built in and have the advantage of once the form is made, they are very easy to make.
