Hello!
Its my first serious post here
I'm building "Metal detector with DSP" for my engineering diploma. I'm form Poland and I'm studying at Warsaw University of Technology.
My goal is to build multi (probably 3) frequency detector.
I have many questions about building a search coil.
Right now I'm using half-bridge to drive transmitter coil with 3 frequency square signal (like in Whites V3i).
And there is another problem. How to calculate the coil ? I want to use about 300mm diameter DD coil. Spectrum: form about 2.5kHz to max 25kHz - in my opinion the most
reasonable.
I've heard that the self inductance of the coil should be around middle of my assumed spectrum. But how exactly can I calculate that ?
Or should I make standard resonant circuit (coil + capacitor) and eventually, try to lower the Q parameter to "fit" whole frequencies ?
I'm using forums calculator to get inductance of the coil. Also Ive heard about Wheeler`s formula which gives good effects.
Could you give me some examples from commercial detectors ? I saw somewhere disassembled coil from V3i but now link is gone.
Regards, Mateusz.
reasonable.
Regards, Mateusz.
