About IDX coils
  • About IDX coils
    hi all guru
    i finish the board but i am not sure aboat the connection to the board.
    and this is the idx board :
    many thanks
    Originally posted by mohandes View Post
    hi all guru
    many thanks
    Hello Mohandes . I got your e-mail . You are at the fun part !!! 1st: It is always good to put some kind of connector on the circuit board where the coil wires are soldered . If you solder and desolder wires too many times , the pc board can get messed up .
    In answer to your question , there is a DD searchcoil photo somewhere on this forum that shows the correct beginning and end in respect to the polarity or current flow [direction]. I will look for the DD photo and if I find it I will post it here .
    Best Regards................Eugene
      The right information is in post 1348 here
      Worked fine first time for my coil.
        hi Mr Engene
        my ? is : correct this pic i wrote the connection pins of the RX and TX coil : IDXpcbfront.JPG
        i think my DD coils are ok just please check above.
        Mr koala well but my coil is DD coil!!
        best wishes and regards
          My coil is DD also. Mark each start (I tied a knot) and wind the same way round. Connect TX/RX start and finish as in post 1348 link above. Follow the colors in both photos shows where each goes. Worked fine for me.
            ok
            thanks
            i check my coils put my result here
            many thanks man
              Hi Mohandes,
              pay attention to the coil shieldings (RX and TX). The RX and TX shieldings may not touch together as they would create a large target (conducting loop at the outline of TX and RX coil). Isolate the RX and TX shielding at the crossing (touching) region.
              Cheers,
              Aziz
