Coil calculator difficulties
  • Coil calculator difficulties
    Hello
    When I run the downloaded coil calculator the calculate button does not display. Any suggestions how to resolve this?
    Did you copy the folder to your Hard drive and then run it? Then click on coilcalc.htm and it should work
      Originally posted by OZDigger View Post
      Hello
      There should be a folder called "buttons" inside the "antenna" folder. If it's not there, then the Calculate button will be missing.
      I had this happen once when the "buttons" folder had mysteriously been moved somewhere else.
        Thanks for the responses, I reinstalled Firefox and that has fixed the problem.
