I recently finished building a TGSL and am in the process of modifying it to make it perform better.
I started with the standard coil 6.0 mh and 6.5 mh (or 100 turns and 105 turns) but then read about
using the Minelab coil on it ( 1 mh and 14.7 mh (approx. 45 turns and 170 turns)).
Well I wound the TX with small diameter wire so it wouldn't oscillate. While I was waiting for the new
wire to come in I used the standard 6.0 mh TX coil with the 14.7 RX without retuning the cap and it
worked great!
So now I'm thinking maybe I can use most any inductance that can be tuned off resonance of the TX.
I've heard of the ampere turns being the important spec on coils so I computed the following data;
Tx = 8700 hz
1 mh
2.5 ohms
15V 150 ma
reactance = 54.6
Q = 21.8
6.75 ampere turns
#1 Original TGSL ***********************************
6.5 mh - 22 ohms - 105 turns with .033uf cap = 10866 hz
Recieved signal - 8V 15 ma
105 * .015 = 1.575 ampere turns
Reactance = 429 ohms
Q = 19.5?
Cap to resonate at third harmonic = .0055 uf = 26618 hz
#2 Minelab Style **********************************
14.7 mh - 34.4 ohms - 170 turns with .015uf cap = 10718 hz
Recieved signal - 12V 10 ma
170 * .01 = 1.7 ampere turns
Reactance = 970 ohms
Q = 28.2?
Cap to resonate at third harmonic = .0025 uf = 26253 hz
#3 Whites IDX Style *******************************
35.6 mh - 70 ohms - 280 turns with .0068uf cap = 10229 hz
Recieved signal - 25V 9 ma
280 * .009 = 2.5 ampere turns
Reactance = 2288 ohms
Q = 32.6?
Cap to resonate at third harmonic = .001 uf = 26674 hz
#4 Made up Big Inductance Coil **********************
45 mh - 120 ohms - 320 turns with .0047uf cap = 10943 hz
Recieved signal - 20V 5 ma
320 * .005 = 1.6 ampere turns
Reactance = 2969 ohms
Q = 24.7?
Cap to resonate at third harmonic = .0008 uf = 26525 hz
As you can see the ampere turns peaks in the IDX coil at 2.5 but the reactance is a bit high
I'm not sure if that will be a problem? The cap to resonate at the third harmonic is a common
value. 280 turns is not too excessive so it appears to be a good choice. I'm not worried about
phases right now as they can be tuned in later. Just trying to make an improvement.
I've heard Q should be 3 to 1 with TX? These values won't work (if I calculated it correctly XL/R)
Other than making the coil heavy is there any reason to limit the turns in the RX coil?
Whites tends to make higher inductances on their RX coils but others tend twords lower values
Not sure why?
Anyone have any thoughts on this?
worked great!
Tx = 8700 hz
1 mh
2.5 ohms
15V 150 ma
reactance = 54.6
Q = 21.8
6.75 ampere turns
Q = 19.5?
Q = 28.2?
Q = 32.6?
Q = 24.7?
Not sure why?
