Hi, I have obtained a damaged Whites Treasuremaster VLF/Disc metal detector. All the electronic components appear to be the originals and there is no damage to the pcb. However, the search coil is a different story as it has been opened by someone who for some reason or other has had the transmit coil removed. The receive coil is intact and the readings across it is a healthy 35 ohms. Is there anyone who knows what the length of the transmit coil should be for this particular model? Or what can I input to get the measurements with the Coil Calculator??
The diameter of this coil should be 5 and ¾”, according to the dimensions of the groove in the polystyrene bed where the windings laid . (The receive coil is 2 and ¾” it appears to be a 32 wire gauge and has 3 parallel capacitors to link it with the TX coil. The middle tappings that go to the red and black wires has a 0.1uf cap across too )
As there are four connections to be made to the receive coil, I take it the TX coil should also be a double coil? Any info would be much appreciated.
