Here's some simple maths: Assume the ECW is square, and you make a nice square cross-section coil with it. It will be square-root of 146 =12 x 12 wire-diameters in size. 12 x 0.25mm (approx 32 SWG) means it will be 3mm x 3mm in size. Ok, the wire is round, so you have hexagonal close packing, and the enamelling thickness is not insignificant, but it would still be 3.5mm x 3.5mm, I bet.
As we've established it's a 'standard' Whites spec coil, it's probably worth just looking out for a compatible vintage Whites coil on eBay. The 8 inch one (4B?) would probably work with it. Carl-NC would probably have some suggestions. I think some current coils they make would also work, have alook, depends if you're wanting authentic retro look or not...
