Hello all,
First, a thank you to Carl for making this site possable and to all who have contributed to this wealth of knowlage...
I have built the Surf PI kit from Silverdog, works fine, its a nice little kit. I have made a coil and have had it sampling reliably to 5.5uS and detecting a 1 euro coin at 40cm in the air. Slight noise detection, as expected in the garage with energy saving lights nearby. Hand not really detected in proximity to coil but slighty noticeable when I touch coil. All good and well untill I put shielding in place. Im using a graphite/varnish mix, 8mm gap on coil shield, spacing between coil and shield is approx 8-10mm. Shield to coil capacitance is 80pF, damping resistor 402 ohms. Surface of shield at the moment is about 4K ohm measured about an inch anywere on coil. The problem I have is the shielding has made things worse, my hand is now detected as if it were a lump of metal and if I put my hand on coil and then remove hand there is a huge signal as if a chunk of metal is rapidly moved towards coil. On the plus side I can open the threshold a lilttle more, but not much. Also if i reduce the delay to about 15uS (I havent measured this to confirm exactly), the effect of touching the coil is drasticaly reduced but my hand is still detected when waved in front of coil.
Any one have an idea why this is happening? Is it a case that I need to reduce the shield resistance quite a bit or have I just killed my perfectly good coil by wanting that bit more from it?
Dave
Dave
