Not quite sure who understands how to design coils properly, but from what I've seen...NO ONE!!
I say this because I have just spent four hours, downloading around 20 coil calculators and no two gave anything like the same results when fed with the same data. Conclusion?
1) It's a black art and I haven't sacrificed enough virgins (I DO live in the UK though
2) No one has the faintest how to implement the equation properly
3) Everyone who has written a calculator is cr@p at maths
That aside, I have a suggestion, which is;
Taking Dave Emerys excellent co-planar coil design article, can some whizz come up with a piece of software (maybe written in VB) which calculates the TOTAL inductance of a coil, based on the Tx coil AND the Bucking coil? That is to say a program which will calculate the whole caboodle.
Give the program the desired operating frequency, coil size (inner / outer), specify the type of oscillator used (Colpitts or Clapp etc) then generate the whole lot to enable you to simply wind the damned coil which would entail;
No of turns, recommended wire dia. former diameter, height of coil for OUTER Tx. SAME for RX coil and SAME for Bucking coil then also give the values of C for the oscillator.
The SAME could be done with a PCB based solution ( http://www.edn.com/design/components...iral-inductors ) you could then put the oscillator ON THE COIL PCB and make an X-Terra type machine. Change coil to get different frequencies.
THB I could do this, but I simply don't have the time. Perhaps Aziz or one of our other resident Genii could do something about this.
Even maybe OVAL Rx coils (Catseye) to give the best of DD and Concentric. Come on, someone give it a go!!
I think Aziz could even work out how to balance a PCB coil too
